General Category => Maintenance => Topic started by: 86FJNJ on March 04, 2026, 10:07:54 AM
Title: Clutch Upgrade Question
Post by: 86FJNJ on March 04, 2026, 10:07:54 AM
If I grab some throttle the bike will feel like the clutch is slipping. Big revs but no acceleration feels like the chain popped off for a second, and then it will eventually catch and accelerate.
In prior posts I've been told this is the typical stripped gear dogs which the earlier FJ's are known for. It's not a big issue, doesn't happen when riding normal which is how I ride 99% of the time, but I'm curious if upgrading the clutch with the springs that RPM sells would help reduce the severity of that slippage?
Also is upgrading the clutch a big job or a pretty easy remove and replace?
Title: Re: Clutch Upgrade Question
Post by: Paul.1478 on March 04, 2026, 01:14:31 PM
I have the same issue and was under the impression a new "spring" from RPM would likely solve it.
EBC Clutch Spring FJ1100 FJ1200 XJR1200 XJR1300 Direct replacement or use as a secondary spring for improved performance.
Price: $55.00
also very easy install, just get a new gasket/oil.
Clutch Cover Gasket; Yamaha FJ1100-1200, XJ1200 and XJR1300
Clutch Cover Gasket
FJ1200/XJ1200/XJR1300
Price: $10.31
I very well may be wrong.
Post by: Pat Conlon on March 04, 2026, 02:38:25 PM
2 different, unrelated issues. Clutch plate slippage vs transmission gear disengaging.
You can fix either one, yet still have the other issue.
Transmission gear disengagement typically happens in 2nd gear.
 Clutch plate slippage can happen in any gear, usually a hard roll on in 3rd, 4th or 5th.
Fixing a slipping clutch will not help nor hurt the transmission gear problem.
Apples and Oranges.
Post by: axiom-r on March 04, 2026, 02:41:37 PM
My clutch was slipping and the first thing I was instructed to look at is my oil to make sure I was not using something with additives that would impact the clutch engagement. This seems like it should be obvious but it is pretty common that an incorrect automotive oil with cleaners or additives was used by mistake or at some point in the bikes life - that will affect clutch grab.
I installed a second disc spring in my bike which doubled up the lever firmness and corrected the slip but not entirely.
I missed the "soft" lever and full engagement that I once knew and went with the Barnett Coil Spring Plate for about $145. It was easy to install. Eliminated all slippage and was a reasonably low pull weight at the lever. I also switched to the Oberon Slave Cylinder and was able to bleed my clutch more thoroughly and more easily than ever before.
I currently have the best clutch I have ever had on my bike...
There are many paths and options on the clutch. Just replacing the OEM spring with a new one and making sure your plates are flat, clean and within tolerance should do it.  Correct oil of course.
Any scoring or burning on the fiber plates after experiencing slippage would result in replacement with a new set for me. If the steels are flat they can be cleaned of scoring and reused.  I lay mine on a piece of glass in the garage and see if they wiggle at all.  Any movement means its warped and a new plate should be used.
tim
Post by: 86FJNJ on March 04, 2026, 03:52:40 PM
Thanks, is there a way to tell if the issue is clutch slipping or slipping out of gear? I've had it happen in 2nd and 3rd for sure, basically I would get the RPM's up to like 4-5k and grab a bunch of throttle and the RPM's would nearly redline but I'd feel the momentum of the bike stop for a second and I'd naturally lay off the throttle and it would catch and start moving. I first thought it was the clutch but then people have me thinking it's the gears. Bike only has 20k miles but IDK how PO rode it.
Post by: Pat Conlon on March 04, 2026, 04:13:40 PM
That sounds like a clutch slip....rising rpm is key. If it a smooth slip, clutch for sure.....if it jerks suddenly, it's the tranny gears.
Then again...You could have both issues.
Fix the clutch spring first.....go from there.
I agree with Tim, the Barnett coil spring conversion is better than the EBC diaphragm spring. I have that kit in all my FJ's.
Post by: 86FJNJ on March 04, 2026, 05:51:32 PM
Thanks pat are the standard springs that come with the Barnett clutch good enough or do I need to buy those heavy duty springs?
Post by: Pat Conlon on March 04, 2026, 06:07:05 PM
The standard (gold) springs are perfect for the stock FJ engine.
