General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: moparman70 on January 21, 2026, 10:34:38 AM
Title: Ideas on removal of insert from cylinder
Post by: moparman70 on January 21, 2026, 10:34:38 AM
A friend bought my old FJ 1200 1986 that I unfortunately dropped in one of the cylinders the little brass insert that was part of the coil wire. ( the part inside the coil wire that attaches to the top of the spark plug.
We have a bore scope and we can see it -- we also are able to grab it with some flexible wire pinchers but the unable to retrieve it with the pinch grabbers due to the overall width of the grabbers once they hold the brass insert.  So basically can pull it through the hole.
Looking for some other created ideas on how to remove -- without a tear down of course.  Is there anything out there like sticky string that is durable enough not to break as well?
any other ideas?
thanks for thinking of ideas in advance.
Title: Re: Ideas on removal of insert from cylinder
Post by: Billy Bananahead on January 21, 2026, 10:43:28 AM
Can you get some plastic or rubber tubing and get one end to fit over the brass insert and if that can't trap it in the bore of the tube then maybe suck on the other end of the tube to get the insert up into the tubing.  :crazy:
Post by: 86FJNJ on January 21, 2026, 11:12:59 AM
new territory for me but can you remove the exhaust, manually turn the engine until that exhaust valve is fully open and then blow compressed air into the spark plug hole and hopefully the piece shoots out the exhaust port? Maybe also put a shop vac on the exhaust port to add some suction while pushing in compressed air into the spark plug hole?
Post by: RPM - Robert on January 21, 2026, 11:13:04 AM
Maybe try some 3m double sided tape on a semi flexible rod to get down in there and just stick it on there.
Post by: RPM - Robert on January 21, 2026, 11:14:40 AM
Quote from: 86FJNJ on January 21, 2026, 11:12:59 AMnew territory for me but can you remove the exhaust, manually turn the engine until that exhaust valve is fully open and then blow compressed air into the spark plug hole and hopefully the piece shoots out the exhaust port? Maybe also put a shop vac on the exhaust port to add some suction while pushing in compressed air into the spark plug hole?
I think the brass insert is too large for it to come out of the valve. If I recall they are about the size of a main jet and unless you got some monster cams in there I don't believe they would have enough lift to get it to open far enough.
Post by: MarioR on January 21, 2026, 11:27:42 AM
Exactly. Intake or exhaust port are bigger so easier to blow it out.
Post by: RPM - Robert on January 21, 2026, 12:02:00 PM
It's actually about twice as tall as a main jet. So I don't think there's a snowballs chance it comes out of the either intake or exhaust valve.
Make sure you have all the pieces when you put it back together as well.
Post by: T Legg on January 21, 2026, 01:08:07 PM
You could try taping a larger mcdonalds size plastic straw to the hose of your shop vac and insert it through the sparkplug hole.
 I don't know whether those are still legal and available in California .
Post by: Bones on January 21, 2026, 02:02:53 PM
Can you rotate it so the piston is top dead and the valves are closed and try and suck it out with a powerful vacuum cleaner.
Post by: 86FJNJ on January 21, 2026, 03:16:01 PM
I might be getting crazy here but since stuff weighs less under water I wonder if sucking it out with a vacuum doesn't work what if you get the cylinder to TDC and fill it with water and then try to suck it out along with the water, it might have a better chance of coming out with the movement of the water and being slightly lighter when in water.
If that doesn't fail turn the FJ upside down and shake the engine until it comes out the spark plug hole.
Post by: red on January 21, 2026, 05:58:16 PM
MoparMan,
 I vote for the vacuum cleaner, with a flexible thinwall tube at the business end.  The tube should be the largest that fits into the spark plug hole.  If you can borrow a Rainbow vacuum, I know of no better machine for suction power + airflow. You will need both.
Post by: Pat Conlon on January 21, 2026, 06:04:46 PM
My thought was similar to Robert's....something sticky
I love that JB Weld epoxy putty. Sticky stuff.
Spray some brake cleaner down there, get any oil or dirt off the insert.
Get a straw, roll some JB Weld putty in a small cylinder and stuff it in the straw, leave a round ball at the end...(the goal is when the putty dries, it does not pull out of the straw)
Working quick,  within 3 minutes of activating the putty, put the straw in and smush it good on the insert. Try and get the end of the insert, not the middle, so you can get it out the sparkplug hole....then don't touch it for 24 hours....let the putty dry.
Once dry....you should be able to pull it up.
Change your oil. It was contaminated from the brake cleaner spray.
Be aware that JB Weld putty is some strong shit....if you stick it to your piston crown, you will probably be able to pull that piston out through the sparkplug hole...  :sarcastic:  :sarcastic:
Post by: Millietant on January 21, 2026, 07:02:34 PM
Why not try some chewing gum, or blue-tak/white-tak oon the end of a piece of thin round wooden dowel, down through the spark plug hole?
Post by: Flynt on January 22, 2026, 09:53:39 AM
Look for a set of "Mechanics Fingers"...  I know Craftsman makes them, that's the set I have.  It's a flexible metal tube with 4 "claws" that open up when you press the other end's "plunger" type actuator...  stick it down hole, open claws and grab the piece by releasing the plunger, then pull it out.
Here's one on eBay for $7.50...  https://www.ebay.com/itm/167509574109
Post by: Gratis on January 26, 2026, 10:15:07 PM
Hey everybody, I'm the lucky guy who bought this FJ. There's a lot of great ideas there. I've tried a bunch of them so far. Still refining my technique, I came close to getting it out with a plastic straw that I can squish down over the part a then apply a shop vac. It's a multi step process to get to that point however and nothing would happen without the borescope in and out in and out. First you have to get it in position to grab it using a small wire, then you have to grab it and put it exactly in the center of the piston. Then slide the borescope inside the straw to locate the part, finally while pressing down on the part pull the camera out and apply the vacuum to the straw. It's like doing surgery through the rectum. That's the best I have so far. I like the water idea and maybe need a Rainbow vacuum, never heard of that one.
Post by: FJmonkey on January 27, 2026, 10:34:34 AM
This is like the "Make it Work" scene in Apollo 13. Problem solving...
Post by: Flynt on January 27, 2026, 10:36:39 AM
Quote from: FJmonkey on January 27, 2026, 10:34:34 AMThis is like the "Make it Work" scene in Apollo 13. Problem solving...
I agree...  put off the mechanic's fingers for a while.  I'm sure there's a harder way that'll work.
Post by: T Legg on January 27, 2026, 11:18:29 AM
Quote from: Flynt on January 27, 2026, 10:36:39 AM
The claw was their first method attempted.
  "We have a bore scope and we can see it -- we also are able to grab it with some flexible wire pinchers but the unable to retrieve it with the pinch grabbers due to the overall width of the grabbers once they hold the brass insert.  So basically can pull it through the hole."
Post by: 86FJNJ on January 27, 2026, 11:43:58 AM
what about a drop of fast curing super glue on the tip of the straw. you said you kind of got it with the straw so maybe some superglue on the straw edge and then once the straw touches the piece hold it for a minute or two and then try to vacuum it out
Post by: Pat Conlon on January 27, 2026, 02:30:17 PM
Eric, Robert and I agree, the secret to success is with adhesives.
If you can't mechanically grab it, or hold it with vacuum, then as Timothy Leary suggested, better living thru chemistry...so to speak.
Can we start a betting pool? I'm in for 5 bucks... :gamer:  :gamer:  :gamer:  :gamer:
Post by: Waiex191 on January 27, 2026, 10:29:52 PM
I'd wrap some good duct tape inside out around a straw.
Post by: Billy Bananahead on January 28, 2026, 05:49:24 AM
Bite the bullet and pull the head off. Then clean the carbon off the valves and piston crowns. (popcorn)
Post by: Sparky84 on January 29, 2026, 02:56:08 AM
Quote from: Billy Bananahead on January 28, 2026, 05:49:24 AMBite the bullet and pull the head off. Then clean the carbon off the valves and piston crowns. (popcorn)
Port/polish, bigger valves , list goes on
Btw Good Luck Gratis
Post by: Gratis on February 10, 2026, 08:13:13 PM
Today was a good day. I :morning2:  got that damn brass piece out. I appreciate all the comments and suggestions, here's what worked: First, borescope. No way to do this with out that. Knowing where the part was I could grab it with the claw, position it TDC and drop it there. Then with the borescope inside a straw I could precisely place the straw, extract the camera and place the vacuum on the straw. Lift the straw with the piece out enough to grab it with hemostats. Then while holding it with the hemostats slip a bent screwdriver under the part for leverage. Then while jamming the piece with the screwdriver dremel a hole into it. Now put a punch in the hole and wobble it back and forth while pulling up. Hope that makes sense. Finally moving on with this project!
Post by: red on February 10, 2026, 09:11:35 PM
Gratis,
Great news! Glad that worked out.
While you have the vacuum out, I suggest that you vacuum out the cylinder to extract any tiny pieces that may remain in the cylinder.
Just a thought . . .
Post by: Pat Conlon on February 11, 2026, 04:21:10 AM
Well done!
Post by: FJmonkey on February 11, 2026, 11:04:16 AM
The thorn is out, the pain is gone. What a chore for such a small item. Well done.
Post by: MarioR on February 11, 2026, 12:04:55 PM
Good job  :morning1:
Post by: FJ1200W on February 12, 2026, 04:37:51 PM
Perseverance pays off!
Well done not over done
