General Category => Maintenance => Topic started by: 86FJNJ on December 02, 2024, 07:38:26 AM
Title: Compression Test Questions
Post by: 86FJNJ on December 02, 2024, 07:38:26 AM
I found this cheap compression tester, it has a 14mm thread diameter adapter but I know the spark plugs on the FJ have a thread reach of about 19mm and this does not appear to be that long. Do I risk destroying the spark plug threads in my head by using this kit to do a compression test? Does the adapter for the compression tester need to have a 19mm reach? Does anyone have any other recommendations for a kit to use?
https://www.amazon.com/gp/product/B0BDCN8NKZ/ref=ox_sc_act_title_2?smid=A1Q7LK027197Q0&th=1
I've see conflicting answers if compression test should be done on cold or hot engine, does it matter?
When doing compression test do I leave the spark plugs in the other 3 cylinders or take them out?
Title: Re: Compression Test Questions
Post by: Pat Conlon on December 02, 2024, 09:41:18 AM
You will be fine with that kit. The threaded hose adaptors are used briefly. I've never blown any out. Don't forget to first warm the engine then hold the throttle plates wide open.
Post by: 86FJNJ on December 02, 2024, 01:20:05 PM
ok thanks, so the compression test must be done when engine is warm and running at full throttle, will do.
Post by: RPM - Robert on December 02, 2024, 02:02:17 PM
Quote from: 86FJNJ on December 02, 2024, 01:20:05 PMok thanks, so the compression test must be done when engine is warm and running at full throttle, will do.
Not running, after running and warm. Take all the plugs out, install the compression gauge on a cylinder and crank with the throttle open until the gauge no longer rises. That is your compression number for that cylinder. Make sure the battery is charged and/or on a charger. A weak crank can give faulty numbers.
Post by: 86FJNJ on December 02, 2024, 03:17:37 PM
ok thanks for clarifying that, I just got a new battery and the crank does seem weak, seems like it cranks slower than I am used to, is that normal for FJ's or is the starter possibly on its way out?
Post by: RPM - Robert on December 03, 2024, 11:25:41 AM
The 2 brush starter was weak from the factory they went to a 4 brush later which increased cranking power.
That said the 2 brush symptoms usually only show up when the bike is warmed up or hot. Or if you have a built motor with higher compression.
Post by: 86FJNJ on December 03, 2024, 03:55:45 PM
Thanks, are the 4 brush starters from later years compatible for my 1986 without modification? If so do you know what year they started using the 4 brush starters?
Post by: RPM - Robert on December 03, 2024, 06:06:35 PM
Someone here probably can confirm but I don't know if they changed in the North American models.
I believe all the XJR models had them but they were not sold in NA.
There are "chinese" 4 brush starters on eBay. I would buy at least 2. I have seen them come apart internally but you can buy 8 for the price of one Yamaha one.
Post by: 86FJNJ on January 01, 2025, 12:47:52 PM
I was able to get the bike running! First time in 15 years, smoked a lot. Would only run on almost full choke the moment I tried to give it throttle or lessen the choke it died. So I'd appreciate any advice about what's happening here since I'm not familiar with carbs.
I did the compression test and numbers are as follows:
Cylinder 1: 150 psi
Cylinder 2: 135 psi
Cylinder 3: 140 psi
Cylinder 4: 140 psi
Are these numbers in the ok range that the bike is worth continuing to restore?
Within a 60 seconds of it starting up I put my hand on the headers and the headers for Cylinders 2,3 & 4 were extremely hot while cylinder 1 was just warm. Is that normal? I thought maybe it wasn't firing on cylinder 1 but not sure how to check that. I pulled the plugs and can see spark on each one although it looks a little weak IMO but these are the original plugs not sure if that would be the plug or the coil?
Also immediately upon starting the bike I blew the 15A fuse for the blinkers and horn so I replaced it with the spare. Is this something I should dig into more could there be a reason for that which needs fixing?
As always this group is amazing and I would not be able to get the bike to this point without your help.
Post by: Pat Conlon on January 01, 2025, 01:33:15 PM
Congratulations on the start up!
Only being able to run on choke means that your idle circuit passages in the carbs are blocked. Suggest a complete disassembly and ultrasound bath with fresh o rings on reassembly as a starting point.
Compression numbers look ok. As you get more hours of running time on the engine, those numbers may change for the better.
Electrical gremlins are a bitch. They take time, logic and patience to track down. A common area for failure in the blinker/horn circuit are the 2 horn wires going down to the horn by the steering neck. The back and forth movement of the handlebars cause these wires to rub against the frame causing the wire insulation to break down. The wires going down to the horn are hot wires (w/ignition on)  meaning the horn works by grounding at the horn switch. These hot wires make it easy to blow a fuse on this circuit even if you don't activate the horn or blinkers. As soon as the ignition key is turned on...pop!
Again congratulations! Keep at it!    Let us know how you're doing...
Happy New Year!
Pat
Post by: 86FJNJ on January 01, 2025, 01:45:18 PM
Thanks Pat, will be a while before I ride, no clutch or brakes and tires are 20 years old.
I should mention I had just the carb hooked up o an UV tube with no filter element, not sure if that matters.
Is there any reason to think it was not running on cylinder 1 with that head pipe being significantly less hot that the other 3?
Also for what it's worth I've been putting some assembly lube on the carbs and intake boots and that makes it a lot easier to install and remove.
Post by: Pat Conlon on January 01, 2025, 01:49:47 PM
I was modifying my message when you replied.
Get those carbs cleaned. Your cold cylinder can be the result of little or no fuel getting thru the carb.
Post by: Millietant on January 01, 2025, 02:48:32 PM
I'm with Pat, your symptoms read very much like carb issues, with blocked idle circuit passages at least.
Number 1 cylinder exhaust being a lot cooler than the rest is a tell tale sign of weaker combustion. From your description this really can only be from the carbs, or the ignition. There are plenty of potential causes on the inlet side (as you have a spark for the number 1 cylinder and decent compression), but as the bike has been laid up for a long time, blocked jets/circuit passageways are the ones I'd go for first, but while you're looking at the carbs, just make sure the inlet rubbers between the carbs and the head are not seriously cracked (especially no 1 cylinder) and also make sure the vacuum take-off plugs are in place properly, again, especially on number 1.
Good luck with the troubleshooting and keep us posted on your process/progress, with more questions as neccessary.
Cheers.
Post by: 86FJNJ on January 04, 2025, 11:06:52 AM
Is this hole on the top of the carb for Cylinder 1 supposed to be capped or vented to something? I'm wondering if this (being open) might be why my Cylinder 1 header was not hot and likely not running properly during my initial test. The Carb for #2 has a long vent hose which I'm assuming goes to the gas tank and #3 and #4 have caps on them.
FYI I got the bike in already partially disassembled state so I wasn't the one to take it apart to know exactly how it should go back together.
Post by: Pat Conlon on January 04, 2025, 11:34:00 AM
Yes, that port should be capped off if you are using an auxiliary fuel tank.
 That is the vacuum port for the vacuum hose that goes to your vacuum operated fuel tank petcock. When the engine starts, the vacuum opens the petcock and when the engine stops the lack of vacuum closes the petcock.
 By not capping this port off you are letting unmetered air into your fuel/air mix on your #1 cylinder causing a lean misfire condition.
The vacuum hose you see on #2 goes down to the ignition box and is the vacuum advance.
https://fjowners.com/index.php?topic=11690.0
Post by: 86FJNJ on January 04, 2025, 12:06:39 PM
ok so for now as I try to get engine running without a fuel tank and just have an IV tube of gas hooked up to the carbs with no filter on the carbs I should cap off that little vent on cylinder 1?
In my first run test I believe I am running lean based on everyones feedback and what I looked up because it only ran with choke on and carbs are essentially stock and I have F1r slip ons and no filter on the carb.
I'm thinking if I hook up those carbs I got that are set up for a legend with the center fuel inlet and 120 main jets it should run better in this condition although then most likely on the rich side but then I should be able to get it to run without the choke on right?
Post by: Pat Conlon on January 04, 2025, 01:41:33 PM
Quote from: 86FJNJ on January 04, 2025, 12:06:39 PMI should cap off that little vent on cylinder 1?
Did you see my post? It's not a vent....
Post by: 86FJNJ on January 04, 2025, 02:17:27 PM
I used the wrong term but I understand thanks for your explanation, right now I don't have a gas tank so I just capped the hole off and I threw the legends carbs I have on it and it fired right up with no choke and ran really well compared to few days ago when I tried running it with the stock carbs, the Cylinder 1 header is now hot so I believe capping that hole on the intake of cylinder 1 did the trick to get cylinder 1 running. I now feel pretty confident that the engine runs well enough to take the next steps in getting the engine more dialed in which will be ordering the right jets and probably sending carbs to RPM for a thorough cleaning.
Bike smokes a lot but there is a lot of oil in the exhaust and in cylinders from me filling them with oil previously so I hope that burns off after a certain amount of time and I don't have any other issues. The oil in it is 10w-40 with about 5% marvel mystery oil so it is on the thin side but it's been about 25 degrees here in NJ so I felt that was appropriate for my purposes now.
Post by: 86FJNJ on July 20, 2025, 08:22:24 AM
Update after 500 miles of riding, did another compression test yesterday:
Cylinder 1: Was 150 psi, still 150 psi.
Cylinder 2: Was 135 psi, now 140 psi.
Cylinder 3: Was 140 psi, now 145 psi.
Cylinder 4: Was 140 psi, still 140 psi.
Could these lower compression numbers be why I need to have my fuel screws further out so pilot circuit gets more fuel due to lower compression?
Post by: Pat Conlon on July 20, 2025, 06:52:49 PM
See? We told you...get some miles on that engine and your numbers will improve.
Congrats...Good compression numbers.
 The 7% compression variation (150/140) won't affect your idle settings.
 Get that rusty tank squared away. (Electrolysis and POR15)
'Till then, keep riding her!
Pat
Post by: 86FJNJ on July 20, 2025, 07:09:03 PM
Thanks! I still have the 1991 tank on it that really had no rust in it and I'll keep that prob for this season.
Reading through some other posts I see some mention of Yamaha Ring Free wondering if I should use that to help clean it out a bit.
Post by: Pat Conlon on July 24, 2025, 09:42:57 AM
Sure, give it a try, why not? I think you are over the hurdle, getting it running. Just keep riding, things will naturally loosen up.
