General Category => Maintenance => Topic started by: 86FJNJ on September 28, 2024, 06:25:53 PM
Title: Any trick to getting off gasket from oil pan? Do all 4 headers get gaskets?
Post by: 86FJNJ on September 28, 2024, 06:25:53 PM
Took oil pan off to check and replace gasket. Having a hard time getting gasket off, is there any trick to it? I tried using a sharp razor but that seems to scrape into the metal so I stopped.
Also when I pulled the exhaust there only appears to have been tow exhaust gaskets, there is one on pipe 3 and the other fell off so not sure where it was but I don't see any other gaskets in the heads. Do I put in 4 new gaskets? Did the last person who did this leave two out?
Title: Re: Any trick to getting off gasket from oil pan? Do all 4 headers get gaskets?
Post by: fj1289 on September 28, 2024, 06:59:25 PM
Removing old gaskets from aluminum is a pain!
I think they make some hard plastic style scrapers for this.
Look really carefully for exhaust gaskets - both in the head, and on the ends of the header pipes.  I've ended up with two gaskets in place before ... should have paid more attention!
Post by: 86FJNJ on October 27, 2024, 07:10:14 PM
After trying many other things, what worked in getting the gasket off was a tungsten gasket scraper from amazon, although it did dig into the aluminum a bit so I then made a block sander from a piece of 2x4 and some 400 grit sand paper to level it out. hopefully I never have to take the oil pan off again
