General Category => Maintenance => Topic started by: FFGO on September 06, 2024, 08:10:10 PM
Title: Starting issues (hot)
Post by: FFGO on September 06, 2024, 08:10:10 PM
I have a persistent but intermittent starting problem.
1984 FJ1100. The bike usually fires up right away when cold. Sometimes on the second crank after the vacuum has allowed fuel into the carbs. I'll run down the hill and do some errands in town, stop and go traffic. On one of the stops it won't fire up right away and it seems like I only get 2-3 tries and then the battery is too low to get a good crank. If I put some cables and a booster battery on it, the bike will flash up immediately.
I bought the battery last year. Plain Jane lead acid. I went through an issue with the alternator last year but that's sorted. Do I need a battery with better CCA? Should I run relays to the coils?
What do I need to fix this unreliability?
Title: Re: Starting issues (hot)
Post by: Pat Conlon on September 06, 2024, 11:51:22 PM
Could it be that your starting problem isn't electrical related, but fuel?
 I suspect your fuel petcock is failing.
Take the petcock vacuum line off at the intake manifold, clean the end of the hose, and suck on it...can you draw air? (You shouldn't) while sucking on the hose put your tongue on the opening of the hose, does it hold a vacuum? (It should)
Post by: FFGO on September 07, 2024, 12:34:33 AM
Thanks Pat. I'll check it out tomorrow.
It does seem like the battery gets weak, but the next stop/start it will be fine. I should definitively eliminate the possibility of the problem being a vacuum/fuel issue.
Post by: Meltdown480 on September 07, 2024, 06:28:26 PM
I also have a similar issue. Starts cold on choke fine, will drive 15 min to gym in 100 degree weather. Then when I get back on an hour later wont start even with full choke until I give it throttle. Have rebuilt carbs and a new rpm petcock
Post by: Pat Conlon on September 07, 2024, 10:08:38 PM
For ALL FJ's with vacuum petcocks ('84-87)
Double check to make sure your fuel line is routed correctly.
 The oem fuel lines get soft when hot and can pinch off fuel flow if routed incorrectly.
The correct routing looks counter intuitive...still, follow it.
See my signature line.
Post by: FFGO on September 08, 2024, 10:23:47 AM
I took the petcock apart, and all seemed good. Fragile little unit, I could see how it could easily get hung up.
Yes, I'm always diligent about the fuel line routing. Yamaha felt a label was necessary so I've always felt it must mean something.
We've had company over the weekend so I haven't tried it out since. See what happens this week.
Thanks for the help.
Post by: FJmonkey on September 09, 2024, 06:53:26 PM
On my 86' I found cracking the throttle open just a little when hot cranking helped. A 4 brush starter has fixed this problem for many as well.
Post by: FFGO on October 04, 2024, 10:29:29 AM
After some more riding I feel I've narrowed down the issue. I think that a lot of the "in town" riding just doesn't spin the alternator enough to keep the battery in a full charge state. Too much idling at stop lights etc. Since realizing this I haven't had a problem until yesterday. There was a bad accident on the highway and traffic was backed up and rerouted. The bike started to get hot and then died. I pulled over and let things cool off. I had just returned from sort ride to the next town ~100kms and I had been using the grip heaters. I forgot the heaters when I got in the traffic jam and they quickly sucked the life out of the battery. I think a good battery with lots of capacity should fix the issue. I'm a cheap ass bastard so I'll probably try and mind the discharge issue and replace the battery when it reaches its end of life. Haha.
Post by: Pat Conlon on October 04, 2024, 01:01:43 PM
Yep, a weak battery causes all kinds of weird symptoms.
Turn up your idle speed to 1,000 or 1,100 rpm, helps a bit with battery charging.
Speaking about battery charging, check your RED PLUG https://fjowners.com/index.php?topic=19557.0
 If your bike gets hot often realize that the stock FJ carb jetting is on the lean side (lean engines run hotter)
Re-jetting your carbs will richen up the fuel/air mixture and your engine will run cooler.
Suggest increasing your pilot jets from #37.5 to #40 or #42.5...shim your jet needle 1/2 step and bump your mains up to #117.5.
Pat
Post by: FFGO on October 18, 2024, 07:28:38 PM
Thanks Pat. I had previously replaced the red plug. It was melted on the inside. Looked good on the outside.
The idle is set nicely at ~ 1100 rpm.
I had previously added a couple relays to the high/low headlights. At the same time I changed the H4 55/60 watt bulb to an off-road bulb at 90/130 watts. That might do it!
Hopefully I won't melt the headlight housing or anything else!
Post by: Millietant on October 20, 2024, 10:48:18 PM
I ran 100/150w headlight bulbs in my FJ for decades, without any issues of overheating or damage to the light unit. About 3 years ago I switched to an Osram LED headlight bulb (6500 lumen) and it's brilliant.
Regarding the starting issue - do you still have the heat shield between the engine and the carbs?. Fuel can evaporate from the carbs and make initial starting a touch sketchy of the engine is really hot when the bike is parked.
Is your battery fluid kept topped up - after spending time at high temps in traffic saved on tours in hot climates, I need to keep my battery topped up. If it dries out, it loses power. My charging rate is good (not too high) and my current battery has been on the bike for 6 years - every time I put the bike in the garage, I plug it into my Optimate smart charger, so it's always fully charged when I get to ride it.
Post by: Old Rider on October 21, 2024, 04:49:09 AM
If engine wont turn when really hot you may have the old 2 brush starter.I had same problem
but after i installed a 4 brush that came on the fj from 88 or 89? the engine always starts up when superhot.
If buing one from ebay OR RPM  you can se the difference on the housing. The 4brush type has no screws on the housing. here is a pick from when i changed mine to 4 brush.
i also have done a headlight relay mod with a 100w bulb ,but now i think i will switch it out for a phillips LED bulb that only draw 30watt .it is plug and play.I have done that on my old kawasaki kz900 and the difference was like driving with parkinglights to rally good light i post a pick of that phillips bulb to i was told that they will vibrate and blow out fast but i have used it 2000miles so far with no problems.4 brush vs 2 brush starter (2)rez.jpg
Post by: Old Rider on October 21, 2024, 04:52:26 AM
