Several years ago I remember Aviation Fred did this mod.. (to Casper?) it looked bitchen, and I have always wanted to do the same.
FYI, for the lucky '91-95 FJ owners, clear lenses are readily available on the German eBay...but not so for the '89/90 nor are they available for the '86/87 ('86/87 are different from the '89/90)...and then along comes George.
George ( gdfj12) made some lenses for his '89 and he happened to have an extra set I snagged.
Following what Fred did...Here's link to the combo LED bulbs I used: https://www.superbrightleds.com/1157-switchback-led-bulb-dual-function-60-smd-led-tower-a-type-bay15d-bulb (https://www.superbrightleds.com/1157-switchback-led-bulb-dual-function-60-smd-led-tower-a-type-bay15d-bulb)
I think they look great on the white '89s
(https://fjowners.com/gallery/12/49_01_02_24_6_45_20.jpeg)
Use the combo LED white running light with amber turn (yep, gotta add resistors)
(https://fjowners.com/gallery/12/49_01_02_24_6_46_20.jpeg)
The amber turn lights with the LED bulbs are especially bright about twice the brightness over the stock bulb.
(https://fjowners.com/gallery/12/49_01_02_24_6_47_42.jpeg)
Sorry, no outdoor picts...it's raining cats and dogs today.
Thanks George...I hope you make more, folks will be interested... I think they look bitchen.
Cheers. Pat
They make LED bulbs that switch from white to orange, when used as turn signal bulbs.
The bulbs are always on; they just change color whenever the turn signal is used
These are called "switchback" LED bulbs.
I was wondering if this type is what you have used there, and if so, do you have the Part Numbers?
Yours seem to be brighter than what I have found on the market.
Thanks.
Hey Red, I posted a link to the LED bulbs I used.
That is Awesome Pat.
I have also contacted George about a set of Clear lenses for Casper.
I have used the Switchback bulbs on the 95 FJ1200 for years.
Fred, Yep, I forgot about your '95...that's the bike you did the mod on...thanks for planting the seed!
Looks good. What jead light bulb are u using?
Quote from: manden on July 17, 2024, 05:41:11 PMLooks good. What jead light bulb are u using?
Cyclops 10.0 LED with the Ultra upgrade.
https://www.cyclopsadventuresports.com/Cyclops-100-H4-LED-headlight-bulb_p_192.html
