General Category => Modifications => Topic started by: joebloggs on September 01, 2023, 05:00:42 PM
Title: 3cv safety relay
Post by: joebloggs on September 01, 2023, 05:00:42 PM
Anyone know what signal the safety relays receives from the clutch switch?
Title: Re: 3cv safety relay
Post by: fj1289 on September 02, 2023, 10:45:49 AM
Dude, with all these electrical questions you REALLY NEED to find a Yamaha FSM and study the wiring diagram(s).  The electrical sections are laid out VERY WELL and very clearly break out all the sub-systems.
Post by: Pat Conlon on September 04, 2023, 10:33:57 AM
I don't understand the question, what signal?  It's a 12 volt electrical signal...on a normally open circuit.
Post by: joebloggs on September 07, 2023, 07:15:32 PM
Quote from: Pat Conlon on September 04, 2023, 10:33:57 AM
I mean voltage, I don't want to find out the hard way that Yamaha reduced the voltage to the igniter
And yes, I need a good wiring diagram
Post by: racerrad8 on September 08, 2023, 07:13:13 AM
The ignition system voltage is full, battery voltage.
These engine and ignition system have been used in race cars for 30+ years and the are run from a bare bones wiring requirement and a toggle switch.
Post by: fj1289 on September 18, 2023, 03:16:16 PM
Quote from: racerrad8 on September 08, 2023, 07:13:13 AM
Link to the bare bones system Randy referred to:
https://fjowners.com/index.php?topic=16278.0
And diagram for 84/85:
https://fjowners.com/index.php?topic=6477.0
Post by: joebloggs on September 18, 2023, 03:26:43 PM
Quote from: fj1289 on September 18, 2023, 03:16:16 PM
I've seen that a couple of times while looking for answers, tbh now I've decided to wait until a 1TX fairing turns up I will stick with the stock 3CV loom, no point in reinventing the wheel as they say, I'm going to still have to find a new home for the igniter under the fairing but by keeping the loom where it was designed it makes hiding the battery, fuel pump relay and starter solenoid a little easier.
Of course finding a 1tx fairing is going to take time, or a bit of luck
