Am going to remove the footrest hangers/plate and fit a pair of Busa rearsets, what I would like to know is, is there a off the shelf shorter swingarm spindle I can use or is it a case of fitting spacers?
(https://fjowners.com/gallery/12/5495_30_07_23_2_16_02.jpeg)
Use Spacers.....I'm not aware of a shorter swing arm pivot bolt.
Q: How will that 'Busa plate be mounted?
I see the two smaller rear brake m/c mounting bolts, but only one bolt for the 'Busa plate.
Are you planning on an adapter plate to go between the 'Busa set and the FJ frame?
Quote from: Pat Conlon on July 30, 2023, 05:33:33 PM
Spacers it is then.
Yes, a plate will be used to mount it, tbh it will need spacing off the frame to clear the master cylinder/subframe rail. It's position governed by the exhaust and the subframe tubing. A top exit master cylinder will allow it to be mounted as close as possible.
