I have a 1200 3cv with blue spots that I want a set of lines making for, I'd like a two line set up with one full length line and one over the fender to the other caliper.
Couple of questions.
What angle of banjo's should I specify?
Length of both lines?
Most dual line kits run both lines straight from the master cylinder to the calipers - fewer places to trap air in the system that way. To do it the way you specify - you will probably need to figure angles, lengths, etc yourself since this is much less common.
