General Category => Maintenance => Topic started by: balky1 on February 25, 2023, 02:42:11 PM
Title: Carb jetting recommendation FJ 1100
Post by: balky1 on February 25, 2023, 02:42:11 PM
Hi guys,
I need an advice. I have the carbs on the bench and looking what jets are in:
air: 160
pilot 40
main 105.
Bike has air box and stock exhaust, stock needles. Ran fine, I have the carbs dismantled to change O-rings and joints, but it is a good opportunity to change the jetting also if needed.
Summers here get hot, to around 35-40 °C. Most of my riding is between 0 and 500 m above sea level, but I do at least one trip per year to altitudes between 2000-2500 m.
What jetting would you recommend? I think those mains should be larger, but rode just fine.
:drinks:
Title: Re: Carb jetting recommendation FJ 1100
Post by: Bones on February 25, 2023, 03:12:02 PM
I'm in Australia where it also has high temperatures, it's our last month of summer at the moment and can't wait for cooler weather to come along. Can't remember what my air jet is but I'm running 42.5 pilots and up'd my main jet to 120 and it goes like a cut cat. I think standard size main is around 110 so yours sound a bit small. Edit: just read yours is an 1100 so not sure if they were the same as the 1200.
Post by: Pat Conlon on February 25, 2023, 03:53:24 PM
Runs fine? Why change? Keep what you have....
...or go the minimum, keep the #40 pilots, bump the main to 110 or 112.5 and call it a day.
If you ever lose the air box (UniPods) just shim the needles 1/2 step.
If you also put a pipe on and ignition advance, go with 42.5 pilots, 117.5 or 120 mains. 1 full notch up on the needles.
Experiment, see what you like.
Post by: RPM - Robert on February 25, 2023, 04:38:19 PM
Sounds like you have a restricted model. I built a few XJR that had very small main jets and different main jet needles in order to reduce hp. If changing jetting you will likely need to change the main jet needle and also make sure you have the "unrestricted" intakes.
Post by: balky1 on February 26, 2023, 02:49:56 AM
Thanks guys.
Yeah, I'll try 110 mains to see where it gets me.
It was a restricted model from Switzerland, restricted to 100 HP. I already have the new carb joints from RPM. I suppose those mains are a part of it. But, like Pat said and what I was also thinking, if the bike ran fine don't fiddle too much, right?
Post by: balky1 on February 26, 2023, 03:16:24 AM
BTW, are those aftermarket paper float bowl gaskets any good? I have 4 new ones sitting around.
Post by: fj1289 on February 26, 2023, 11:52:22 AM
Quote from: balky1 on February 26, 2023, 02:49:56 AM
Thanks guys.
I'd give jetting a shot - there can be a big difference between a bike that runs "well" and a bike that runs "right"!  The old phrase "the best you have ridden is the best you know" - you won't know if it can be better or not unless you try...
Post by: balky1 on February 26, 2023, 12:20:08 PM
Quote from: fj1289 on February 26, 2023, 11:52:22 AM
Thanks guys.
That is my reasoning as well. Will try it.
Post by: RPM - Robert on February 26, 2023, 04:31:05 PM
Pop up a pic of the main jet needle as well. Maybe see if there is any marking on them.
Post by: balky1 on February 27, 2023, 06:44:37 AM
Quote from: RPM - Robert on February 26, 2023, 04:31:05 PM
Where are the markings usually located? Do I need to separate it from the diaphragm to see it?
Post by: RPM - Robert on February 27, 2023, 01:07:14 PM
Mikuni marks them close to the top where the c clip is
Post by: balky1 on March 26, 2023, 03:54:55 AM
Needle markings: 5FZ62, clip in the middle of 5 positions.
Post by: RPM - Robert on March 27, 2023, 06:23:18 PM
The 1100 are marked 5FZ63 in the states and the 1200 is 5FZ72 so I can't confirm the needle. If it just an adjustable 1100 needle with flat bottom slides. We usually end up around a 117.5 main jet and the needle shimmed up.
Post by: balky1 on March 28, 2023, 02:10:01 AM
This is a Swiss model so I expected something different. They don't look to be ever touched by anyone. They are flat bottom slides, yes. As per instructions from this thread, I've put 110 mains (were 105) and left the needles in middle position from 5 slots.
(https://fjowners.com/gallery/12/4914_28_03_23_1_09_10.jpeg)
Post by: Pat Conlon on March 28, 2023, 10:05:03 AM
Did you remove the restricted carb manifolds?
Post by: RPM - Robert on March 28, 2023, 10:38:43 AM
Sorry, just went a re read, I didn't realize you had the airbox on it still.
A 110-112.5 is what you need. We run a 117.5-120 with the pods and a few degrees of ignition timing on the 1100.
I would change the air bleed to a 155 or change the pilot to a 42.5, however. Either will work but it will make the bike start much easier and get off the need for choke quicker.
Post by: balky1 on March 29, 2023, 01:24:13 AM
@Pat
Yes, that was the point of restriction I was aware of long time ago, but never looked at the jetting until now.
Post by: balky1 on March 29, 2023, 01:42:31 AM
Quote from: RPM - Robert on March 28, 2023, 10:38:43 AM
Thanks, I'll keep that in mind for the next time, now is all buttoned up. Air pods are something for the future, after the rubbers on the air box deteriorate.
I am having problems in finding new fuel line so the tank is still not in position. Automotive high-pressure line that I tried to fit is just too stiff. Carbs are synced and seems ready to go.
One thing I've noticed while syncing was the slight popping through exhaust when on idle, after blipping. And idle dropping then returning to normal. It seems I've solved the problem with opening the mixture screws for 1 and 1/4 turns out. I hope I did ok (the problem is I have no idea how many turns out they were before, so I don't have the complete number of turns out - before me a mechanic was the last one to fiddle with it 50 000 km ago, always seemed a bit lean on idle so I suspect they were not that far out; honestly, I was afraid to fiddle with mixture screws because last time I couldn't get it to run ok)? But the test ride is still on hold to check. That will give some definite answers.
I did notice also that I went through about 750 mL to a litre of fuel while syncing which lasted some 45 minutes (with a fan). I never payed attention to such things so I'm not sure whether it is too much? Not leaking anywhere, floats at a range of about 22.7-22.9 mm, measured as per instructions here. Fuel level on the bench was spot on, but the manual says the bike needs to be running while measuring. Hence I don't know whether my bench fuel level means anything or nothing? I guess the test ride will give all the answers.
