Hi guys.
The great FJ modding website "fjmods.co.uk" is not working for some days ago. Any idea what happened with it ?
Im really sad 'cause i just started to work on my 1TX, im doing the FZR1000 Exup front wheel and Ducati Monster 43mm USD telescope modification, and i need all the infos about that. After that i will continue with the 1000 Exup rear wheel or rear end conversion...
Look up the waybackmachine on google. Enter the address of the website, you might be lucky that they have a copy of the site stored with the info you need.
Vilike,
The Wayback Machine is a good source. Once you give WM a website address to find, it will show you a calendar of the last few years, with the dates marked when a "snapshot" was taken of your site for you. Not all of the links on a website will be recorded though. If you are on the page you want, and a link you want is not recorded, don't give up. Go back to the Wayback Machine and pick an earlier or older date than your first selection. Check the link you need on that page. Repeat as needed until you find a past page with the link you need which works, or until there are no more "snapshots" left to check.
Alternately, the link you need from the orginal page may have some "snapshots" all to itself. Get the link address from the page you wanted first, then ask the Wayback Machine to search for that exact address, independently from your first search.
Happy hunting!
Hey its working, thanks a lot guys !!! :good2:
