General Category => Modifications => Topic started by: woodcreekpete on July 26, 2021, 07:27:13 AM
Title: I need a measurement
Post by: woodcreekpete on July 26, 2021, 07:27:13 AM
I'm looking for the distance down the fork leg from the bottom of the lower triple to the axle centerline. 88-90, forks at their stock height. Measured with the bike on the c-stand and the front wheel off the ground and unloaded.
Thanks, Pete
Title: Re: I need a measurement
Post by: red on July 26, 2021, 07:45:14 AM
Pete,
Would this measurement be the same for all varieties of the FJs?  They may vary by country.
What model do you have?  If you add that info to your profile/ avatar/ signature, we would know without asking.
Post by: RPM - Robert on July 26, 2021, 10:37:39 AM
Quote from: red on July 26, 2021, 07:45:14 AM
Pete,
I believe they are different. There are 3 different lengths of fork tubes between the generations.
That said I don't have an 89-90 to measure here, currently.
Post by: oldktmdude on July 26, 2021, 05:15:02 PM
   G'day Pete, 520 mm from bottom of lower triple clamp to centre of axle. Sorry I don't and won't do imperial measurements.
This was taken from my 1990 1200 with forks in original position and front wheel raised off the ground.
  Regards, Pete.
Post by: woodcreekpete on July 26, 2021, 09:59:40 PM
Thanks, Pete - exactly what I needed.
