General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: aviationfred on July 21, 2021, 08:02:17 PM
Title: Clutch Slave Cylinder Woes
Post by: aviationfred on July 21, 2021, 08:02:17 PM
I have seen the recent post about a faulty clutch with loose slave cylinder bolts. Keep those bolts tight and by all means, use a torque wrench
When I purchased my 1990, it had 1/4 x 20 all thread and nuts holding the slave cylinder on. Over the years the threads in the engine case had weakened and I had a complete clutch failure. Pull the clutch lever and you could see the slave cylinder physically move outboard. I attempted to make a repair with M8 helicoils. The forward mount hole had been so wallowed out that when I attempted to install the slave cylinder the mount boss in the case broke. I am looking at a few options and directions to solve the new issue.
Title: Re: Clutch Slave Cylinder Woes
Post by: T Legg on July 21, 2021, 10:01:49 PM
That sucks Fred. A broken mounting bolt on each half of the case pretty much finishes off your engine. I'm facing the same thing x three on my yellow 1100 that had the chain break. The only solution I can see is disassembly and some very fancy welding and machining. In my case it will probably be cheaper to get another engine.
Post by: FJ1200W on July 22, 2021, 02:24:54 PM
Epoxy in a stud - possibly even adding the broken piece back in, run a safety wire around for reinforcement.
Proper prep is critical, as you know.
Not sure if you could drill a tiny hole for a small drift pin from the remaining sidewall into the stud - then epoxy it all in place.
If you need a set of cases, I might be able to help you out.
Deal of the day.
Post by: Pat Conlon on July 22, 2021, 02:38:09 PM
Clean it out (real good) TIG weld in some filler, drill it out (use a drill guide bushing) and tap it.
Paging Carson City Paul, can you make Fred a drill guide bushing so he can keep that new hole centered?
Post by: Carson City Paul on July 23, 2021, 10:00:10 AM
I could do that. It would probably be a one time use due to soft material (non heat treated steel).
Post by: Carson City Paul on July 23, 2021, 10:08:32 AM
Quote from: aviationfred on July 21, 2021, 08:02:17 PM
The biggest problem with installing helicoils is, you are thinning the wall of the boss and making it weaker (more prone to breakage).
I would only do that as a last resort... if it's not stripped, don't do it.
