General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: mike g on August 07, 2020, 03:24:23 AM
Title: porous block?
Post by: mike g on August 07, 2020, 03:24:23 AM
I seem to have an oil mist on the right front of the block (where the oil goes up the stud) I've checked that it isn't leaking at the head gasket (or base) also the oil cooler hoses and front fork. only thing I can think of is the barrel casting is porous, any one had this issue? and if so any fixes?
Title: Re: porous block?
Post by: ribbert on August 07, 2020, 05:16:11 AM
Quote from: mike g on August 07, 2020, 03:24:23 AM
Mike, I'd be looking elsewhere for the source of the misting, for a number of reasons casting porosity is unlikely to be the culprit. However, Randy's the man, he's seen the inside of more of these engines than anyone, I suggest you wait for him to weigh in, he'll know where it's coming from.
Post by: Paul.1478 on August 07, 2020, 07:50:25 AM
I had oil "misting" on the right side of my 93. First noticed on my boots after a ride. After cleaning and adding some cornstarch to track the leak, it was coming between the head and barrel at the galley that brings oil to the head. there is a small rubber gasket that failed. May by your source. not a hard fix but I would not want to do it again.
good luck.
Post by: red on August 07, 2020, 09:25:27 AM
Quote from: mike g on August 07, 2020, 03:24:23 AMI seem to have an oil mist on the right front of the block (where the oil goes up the stud) I've checked that it isn't leaking at the head gasket (or base) also the oil cooler hoses and front fork. only thing I can think of is the barrel casting is porous, any one had this issue? and if so any fixes?
Mike,
Clean that entire area as well as you can, and spray aerosol body powder on the areas where you have seen the oil.  Watch that sprayed area closely (often) and the powder will tell you where the oil comes from, before the oil can spread all over.  It won't fix the leak, sure, but you will know what you need to fix.
Post by: mike g on August 08, 2020, 02:09:02 AM
Quote from: red on August 07, 2020, 09:25:27 AM
Mike,
I thought that joint might be an issue and ran it with some tissue wedged in the gap - but the inside stayed clean, so don't think it's that. But the oil does go up that corner of the block which was leading me to think of the porosity issue, I don't get oil on my boots, but the pannier (when fitted) does pick up a mist.
Post by: mike g on August 08, 2020, 02:12:15 AM
oops, that didn't work how I intended,
thanks for all the prompt replies,
I suppose i will need another go at the track and trace, I think i've still got some talc in the garage!
Post by: racerrad8 on August 09, 2020, 11:23:54 AM
Pictures of the area in question will help. You say the block, but is that the case or the cylinder?
Post by: mike g on August 10, 2020, 09:28:23 AM
i mean the cylinder block, seems only to be where the fins are, front right, where the oil gallery is, doesn't seem to be coming out of the head/ barrel joint or base.
will see what i can do picture wise
Post by: Starquest on August 12, 2020, 06:43:25 PM
Yep. I have the same problem. It's the o-ring between the head and the block. Mine is leaking a little bit. I clean before I ride and after a couple hours I see a little oil from the gasket area.
