General Category => General Discussion => What did you do to your FJ today? => Topic started by: RevDeal on July 08, 2020, 10:15:13 AM
Title: New Shock and Relay Mods
Post by: RevDeal on July 08, 2020, 10:15:13 AM
Well no need to go crazy in depth, but I set out to change the shock because it didnt feel good in the corners, almost a little sketch. While waiting for the Hagon shock from the UK I tore into the electrical to add a USB charger. Then I had to address previous owner's wiring.TLDR version
1. Hagon Shock upgrade $375 (shipped)
2. USB dual charger w/ digital volt display, cigarette lighter, and switch (amazon) $22
3.Terminal bus for positive wires, 4 new relays, new colored wires and heat shrink $50
4. Headlight relay mod, horn relay mod, and coil relay mod, and usb charging bank install (time, lots of time)
5. Repainted inner fairing black
Title: Re: New Shock and Relay Mods
Post by: red on July 08, 2020, 10:39:02 AM
Quote from: RevDeal on July 08, 2020, 10:15:13 AMWell no need to go crazy in depth, but I set out to change the shock . . .  I tore into the electrical to add a USB charger. Then I had to address previous owner's wiring.TLDR version
RevDeal,
Got a link for that USB gadget?    :unknown:
Post by: RevDeal on July 08, 2020, 10:45:16 AM
https://www.amazon.com/dp/B07QR3C8N2/ref=cm_sw_r_cp_apa_i_3NEbFbHD5HBRB (https://www.amazon.com/dp/B07QR3C8N2/ref=cm_sw_r_cp_apa_i_3NEbFbHD5HBRB)
Here you go.
