i can't for the live of me figure it out, this is a 1 response thread
i have ridden off with it down more than once, so if it were meant to warn me , it does not
Quote from: mtc on May 11, 2020, 11:51:27 PM
i can't for the live of me figure it out, this is a 1 response thread......
....haha, and normally would have resulted in 20 responses. It is to stop you putting it in gear with the engine running, to avoid what you say you've already done a number of times. If you've ridden off with the stand down, it's either not working or it's been bypassed.
If the sidestandswitch works the engine will not run when sidestand is down so it has been fiddled with.
If you have ridden off with it down i suggest you start a new take off safety prosedure where you ALWAYS take a look down and check that the sidestand is up before you take off. Not cool when you are going into a left turn at some speed.
Quote from: Old Rider on May 12, 2020, 03:25:29 AM
This is incorrect. The engine will run, until the bike is placed into gear with the sidestand down. It will also run while in gear with the sidestand down, if the clutch is held in. Unless, one or or both has been bypassed or is no longer functioning.
1 response each orrrrr.........?
Quote from: RPM - Robert on May 12, 2020, 10:46:50 AM
I believe this is also incorrect.
As far as I know, my FJ works "As it should, from the factory"
If I have the side-stand down, even if I am holding the clutch in, as soon as I click it into gear it kills the engine.............
The only time it should run with the side-stand down, is if the transmission is in neutral.
Just to add to the 1 response.
Part of the training course way back in the 80s focused on a final glance down to check the side stand, before looking over shoulder, then the off. This preflight dance is now ingrained and I think it's good practice.
I'm even in the habit of giving it a touch with the left boot.
Yes, Alan you are correct. I was backwards, was thinking of cranking it in gear with the clutch in and sidestand up. Haven't had my coffee yet. :morning1:
1 response doesn't get it sometimes.
See, turned out to be a decent running thread.
Anymore for anymore?
Quote from: Firehawk068 on May 12, 2020, 11:10:24 AM
so what is the formal name called?
it would be better just to have an idiot light on the dash
where is it connected? i have an aftermarket ignition system, would that be the cause of it not working, since I heard so many different scenarios, do they tend to not work?
do new bikes have this safety switch?
i will i am such a skittish rider lol
Is there an orange wire on your Dyna ignition wire harness? If so, that wire needs to be connected into the sidestand circuit. Your switch mist have a jumper wire installed
Quote from: FJ_Hooligan on May 12, 2020, 11:58:50 AM
yes sir there is an orange, i have to check, but like i mentioned that dyna is on it's way out, so the stock wiring is connected to the igniter? and a kill switch?
so in gear with the clutch released, the engine is "killed"?
or rather if in gear, it will never run or start
and with the clutch out in netrual the engine is allowed to run?
and with the sidestand up the switch is grounded? or open?
i guess it's not that simple after all
Side stand down in any gear except neutral, engine off.
Circuit is normally closed.
Side stand up, circuit closed, engine runs.
Side stand down, circuit open, engine off.
Another thing i usually check before takeoff is that my shoelaces is tucked under so they don't tangle up in gearlever or brakelever kinda embarrassing when stopping at a red light and you just fall over.
Here is a vid of a sidestand down crash
https://www.youtube.com/watch?v=5mQ-5mWNOLo (https://www.youtube.com/watch?v=5mQ-5mWNOLo)
Quote from: Old Rider on May 12, 2020, 12:34:51 PM
Where is Carson City Paul? He didn't fall over....but it was close.
Quote from: Pat Conlon on May 12, 2020, 12:27:32 PM
so you can't delete the switch, you need it to ground the circuit, if removed , the circuit is open and in engine won't run ever
oh wow that sucks, never did that before, but he flip the bike high side, didn't seem like it was a kick stand
Quote from: mtc on May 12, 2020, 01:07:49 PM
To bypass the switch you simply close the circuit.
From the switch follow the wires up to the connectors, Unplug the connectors and use a jumper wire with spade connectors. Easy peesey.
Quote from: ribbert on May 12, 2020, 03:15:23 AM
Not far off, it got to 18 repsonses :biggrin:
19. No problem on my 1100, it doesn't have a side stand switch.
Quote from: krusty on May 13, 2020, 05:09:07 AM
Is there a switch somewhere to retract the side stand :scratch_one-s_head:
Quote from: ribbert on May 13, 2020, 05:03:15 AM
...and now 20! :drinks:
Quote from: Sparky84 on May 13, 2020, 05:17:45 AM
Nope. When I bought the bike I noticed there was no switch so I bought one not realising there was no bracket to take it. I have second 1100 and it doesn't have one either. I have to kick the stand up before moving off.
Quote from: krusty on May 13, 2020, 05:56:40 AM
Are you telling me that those American models have all the bells and whistles and ours have got none of the modern auto stuff :unknown:,
next you'll be telling me theirs came with an oil cooler as standard. :nea:
Quote from: Sparky84 on May 13, 2020, 07:09:44 AM
so Aussie Models come without the switch? mine does not work so it's the same as not having it, yeah I rode the bike yesterday, before i took off it looked at the stand , kicked it up and left, trying to make that a habit now
I like my switch.
I use it all the time to shut my engine off. That way I know my stand is down before I get off my bike.
Don't ask :dash2:
Funny you brought that up. I use my kickstand the same way. I don't think I ever tried to get off the bike with the stand up, but, I really am not interested in seeing if I can pick the bike up off the ground, either.
I can't believe how much heavier these bikes got since I bought my first one in 1991. :sarcastic:
Ted
Theirs came with oil coolers? Could I fit one to mine? :shok:
So somewhat off topic. Clutch safety switches. Mine doesn't work anymore... as in in gear side stand up pull the clutch in no start. Can that be easily bypassed
