General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: the_kirkwood on December 03, 2019, 03:43:20 PM
Title: intermittent tachometer issue
Post by: the_kirkwood on December 03, 2019, 03:43:20 PM
Tachometer is bouncing erratically at idle.  When riding it normally drops to zero rpm with some random twitching from time to time.
Is this likely to be a bad tachometer, bad signal to tachometer or maybe a bad ground?
Is it common for these tachometers to go bad?
thanks in advance
Title: Re: intermittent tachometer issue
Post by: FJmonkey on December 03, 2019, 03:55:30 PM
The ground connection is almost always the issue.
Post by: the_kirkwood on December 03, 2019, 04:10:11 PM
Right on.  Thanks
Post by: Pat Conlon on December 03, 2019, 04:46:40 PM
Also to check is the grey signal wire coming off your right side #2/3 coil. Clean that connection.
