General Category => Maintenance => Topic started by: duanelr on November 11, 2019, 12:28:47 PM
Title: This part fell out of my instrument cluster, what is it?
Post by: duanelr on November 11, 2019, 12:28:47 PM
My bike is an '87 FJ1200. The gas gauge was broken, that's why I took apart the instrument cluster. This was rattling around in the housing. Should I be concerned?
I'm a new owner / first time poster. Thank you.
Duane
(https://ptow4a.bn.files.1drv.com/y4mdFFArYHZGLGENMqVEIoeTGjIqq56TkvqEu1NZCkjFcrRKHArWiXnRGjeF2zyzrbWXRR0M65VIeqAEOC5vtaS6aDpjRnUtLt3sqnzyUknVqFzZWiW1ou8z5thF_jN3C37TG24ExlQ3tWf3CYBlcmcFDLyhZ6gex-U6ArseT2MaM5jud4Uildo5ReUCloiZT2LonPqQ0KvhY1kzLT-DLoI9w?width=768&height=1097&cropmode=none)
Title: Re: This part fell out of my instrument cluster, what is it?
Post by: FJmonkey on November 11, 2019, 01:14:23 PM
That is a counter balance that fell off the speedo. It balances the needle. It can be glued back on when you have the cluster out.
Post by: duanelr on November 12, 2019, 01:51:48 PM
Thank you! When I take it apart, will it be obvious where it goes or is there a picture somewhere that might give me a hint?
On a related subject, my gas gauge moves around wildly, I've purchased an Ebay replacement and it does the same thing. This is common? What might the fix be for that.
Thank you again.
Post by: FJmonkey on November 12, 2019, 02:16:59 PM
Quote from: duanelr on November 12, 2019, 01:51:48 PM
Thank you again.
I am not sure if I took any pictures but one may have been posted from earlier posts. But I remember finding the spot it goes just by looking for it.
The fuel gauge bounces due to a loss of damping fluid. Some have performed surgery to replace it but it is not a simple task for the average mechanic. The process involves making some room for a hole by moving/spreading some very fine wires/winding. Drilling a very small hole, adding a few drops of fluid and sealing the hole up. http://www.fjowners.com/index.php?topic=2026.0 (http://www.fjowners.com/index.php?topic=2026.0)
Post by: Troyskie on November 12, 2019, 11:49:29 PM
Mark, did you note the end comment from http://www.fjowners.com/index.php?topic=2026.msg75073#msg75073 (http://www.fjowners.com/index.php?topic=2026.msg75073#msg75073) ?
"This works a treat for the 1100's, since they have no extra circuitry for simulation of running out of fuel after which the 1200-owners flick the switch."
I've corrected the text from 'at leat' to 'a treat', but STREWTH! Simplest explanation of the 1200 reserve yet.
Post by: Pat Conlon on November 13, 2019, 12:58:40 AM
Yes, we know all about the electric reserve vacuum petcocks on the gravity flow 86/87 FJ's, but the question on the fuel reserve switch function on the fuel pumpers remains unclear...
Question being: When the fuel pumpers go on reserve and the engine begins to stumble, Is it a fuel pump interrupt....or is it an ignition interrupt?
CutterBill's most excellent single line diagram helps me understand the relationship of the fuel tank sending unit, the reserve switch and the fuel pump relay. (Scroll to the right)
http://www.fjowners.com/index.php?action=dlattach;topic=18991.0;attach=14020 (http://www.fjowners.com/index.php?action=dlattach;topic=18991.0;attach=14020)
Post by: ribbert on November 13, 2019, 06:54:24 AM
Quote from: Pat Conlon on November 13, 2019, 12:58:40 AM
....but the question on the fuel reserve switch function on the fuel pumpers remains unclear...
Pat, this guy below seems sure he knows, ask him.
Quote from: Pat Conlon on April 20, 2018, 11:51:44 PM
There is no discussion....we know what happens when the fuel pump FJ's go on reserve.......it ain't got nothin to do with no stinkin ignition interrupt.
Post by: Pat Conlon on November 13, 2019, 07:30:34 AM
It's about anecdotal evidence vs empirical evidence.
I know what happens when I turn on the reserve switch....now I can see why.
Post by: duanelr on November 14, 2019, 09:45:25 AM
I'm sorry, you might need to dumb down your conversation for a new guy.
With the ignition on, I've put my ear against the petcock/tank, flipped the reserve-switch back and forth, and listened for some kind of actuation, solenoid, or anything, I could hear nothing. I've looked at the schematic Pat linked to, I see a reserve-switch but not a petcock. What do the wires running to and from the petcock do? Thank you for your patience.
Post by: Mike Ramos on November 14, 2019, 10:14:09 AM
Quote from: duanelr on November 14, 2019, 09:45:25 AM
Duaneir,
Sir, first the chain lube question and now this question about the reserve switch...?!
Okay, there is no solenoid that is activated by the reserve switch.... The reserve switch function involves the - well....
Anyway, please note Tuned Forks' comment about Pandora's Box & do not ask about that other topic...!
All in good fun!
Ride safe,
Midget
Post by: Pat Conlon on November 14, 2019, 11:01:32 AM
Duaneir, please disregard my post. Sorry about that.
My post, as well as CutterBill's diagram, was referring to the reserve function on the ('89/93) fuel pump FJ's and not to your gravity flow '87.
The only thing in common between the two is that the reserve function involves interrupting fuel.
Your '87 is interrupted at the petcock, and the '89/93's are interrupted at the fuel pump.
Pat
Post by: ZOA NOM on November 14, 2019, 12:21:20 PM
Anybody recommend an oil for our newb yet?  :bomb: :rofl:
Post by: Sparky84 on November 14, 2019, 03:20:49 PM
Quote from: ZOA NOM on November 14, 2019, 12:21:20 PM
Don't forget the grease  :wacko3:
Post by: Pat Conlon on November 14, 2019, 03:42:32 PM
Chain lube....it's all about the correct chain lube....
Post by: 1tinindian on November 15, 2019, 07:55:27 AM
Come on guys, we all know it's all about the tires!
Contact patch and tire pressures is what keeps us alive!
