General Category => Maintenance => Topic started by: Speedy Gramps on June 25, 2019, 03:29:41 PM
Title: Yamaha FJ1200 1991 - Boost Sensor
Post by: Speedy Gramps on June 25, 2019, 03:29:41 PM
a lot of spit back from carbs ,, got that almost fixed .
? ? ?  question  the vacuum line on the #2  carb goes to some type of  mechanical  timing advance  ,, if I  pull the line off  the  carb  side and  SUCK  on the line  ?  should  I be able to suck  air through the  tube  ?  or would /  should it be plugged  and  NO  AIR  is pulled through the  tube ??
I have owned it from day 1   1991  and it does have a vacuum advance under the faring ,,,, I just  do not know  if it is working  correctly  .
Thanks Speedy Gramps
Title: Re: Yamaha FJ1200 1991 - Boost Sensor
Post by: FJmonkey on June 25, 2019, 05:43:38 PM
It should seem plugged. It help flash off fuel when you chop the throttle to meet emissions standards. No performance gain with it.
