Hi all..
My bike has a Magnum silencer/muffler on from when I got it... Its seen better days with the rivets falling out and some battle scares... I had a look and they dont seem to be around anymore...
(https://i901.photobucket.com/albums/ac220/ribz0/Yamaha%20FJ1200/20180930_103111_zpsdatgb2yb.jpg) (https://s901.photobucket.com/user/ribz0/media/Yamaha%20FJ1200/20180930_103111_zpsdatgb2yb.jpg.html)
Would another brand slip onto my system there or is it all matched? Also, do carbs need to be re-tuned if im changing mufflers?
Measure the pipe diameter where it slips on. This will help you pick a can that will simply slip on. Almost any can rated for our liter size engines will work. As long as they don't have a mounting tab welded in the wrong place. The RPM exhaust looks similar in size and configuration and uses a clamp for a mount tab. And unless you are going back to restricted can(s) like stock then you most likely do not need to rejet. Assuming is was jetted properly for that pipe. Does it still have an air box? That is the other restriction in the system.
Thank you FJMonkey...
The guy i got it from reckons the carbies were done... he had it for 17 years but i can be certain... I wouldnt know how to tell or what to look for... but it goes well... :biggrin:
I will have a look at RPM... but will need have a measure when i get home next week...
yes.. it has the standard box and filter... so what is recommended to make these thing breathe better?
Oh... and sorry for the double take on the pic... damn trigger finger...
So how do I remove a pic? I cant seem to locate the "edit" button...
On the inlet side, this product is well received on this forum. I installed a set on the FJ this Fall. RPM's exhaust is going on this winter.
http://rpmracingca.com/proddetail.asp?prod=Carb%3ARPMPod (http://rpmracingca.com/proddetail.asp?prod=Carb%3ARPMPod)
I fixed the second image issue. You have about 30 min to edit your post, after that a moderator needs to mod. The important part that you mention is, it goes well. A very good sign. If the airbox is still in use then I would not worry too much when you swap out the new can. Most aftermarket cans are free flowing. So changing from one to another should have little effect. Regarding breathe better. The FJ breaths quite well with plenty of grunt to prove it. If you want more, then swapping the air box for Pods and a proper rejet will get you more grunt when the throttle is wide open. As much as I enjoy the moments of WOT, I really can't spend much time there. If I did I would develop calluses from handcuffs.
Ok thanks Joe... I was wondering about pod filters... so thanks for the info!!
Yes... I have been drooling over the SS system at RPM.... please keep us posted on that!!
Eric
Thank you for that FKMonkey... ill remember that... 30 mins... :good2:
Yep... I can relate to yr WOT view... and as much as there isnt anything better in this world than the total absorption of all yr senses pinging at 300k/h..... our time as free men would be very limited... :biggrin:
As for how the bike goes... im more than fine with it... Good to know about pods and re-jetting... thanks very much!
Eric
Eric, this is what the box of RPM joy looks like.
Oh really!! dont show me that... Ill only want to buy one!!! You big tease!!!
Gah.... so much joy.....
Im sure it would look so much better on the bike... not still in the box!!!
And then when you unwrap the box of joy and install it all this is how it looks. Unfortunately for you our $ sucks against the US$. I got mine when we were 1 to 1. About $1200 landed at my door. Add about 30% now.
Wot Mark said.
I've recently bought a ColorTune plug to go with the CabTune balancers.
Mate, total of about $160 Aussie delivered for both. You will have no fear of tuning your carbies again & as I've just learnt, every change in the system ultimately requires the carbies being adjusted for a smooth ride.
The absolute total benefit of these two items is a knuckle head like me can get the carbies tuned in less than time than it takes for my beer to get warm (unless they're f@!#ed and you need to clean them :ireful:).
Gee... thanks Mark!! rub that salt in... its ok.... But WOW!! looks so good!! The $$$ does hurt no matter how you break it down...
Australia is such a nanny, fun police country.... gah... makes you wanna pack up and leave sometimes!!!
hi ya Troyski... yes... that will be my next purchase... i like to do as much as i can myself... i luv SU's which i have on a couple of cars, so i think i could have a go at the carbies...
https://www.ebay.com.au/itm/4-Column-Carbtune-Pro-Carburettor-Balancer-Carb-Vacuum-Gauges-with-toolpouch-/290724003198 (https://www.ebay.com.au/itm/4-Column-Carbtune-Pro-Carburettor-Balancer-Carb-Vacuum-Gauges-with-toolpouch-/290724003198)
Is this the sort of gear you mean?
Quote from: Ribz0 on December 06, 2018, 05:15:24 AM
Well don't come here then !!!!!!! Speed camera's (especially "average speed camera's") on every motorway, speed camera's on all the best biking routes, our police not allowed to engage in vehicular chases of criminals, young drivers can't afford car insurance without "insurer approved" fitted vehicle telematics and video recording systems....nanny state on steroids for everything else (FFS they want to put trackers in registration plates)!!!
Aus still seems to be a place where you still have plenty of freedom right now.
Hi ya Dean... hmmm... ok... that does sound... well... somewhat restrictive...
There is freedom as in space and open road here no doubt, and here in WA, we do have it better than some states... for now... but it would just be un-Australian if we didnt have a whine about something... lol...
Im glad i did most of my "silly" stuff back in the 80's and 90's, before social media was around to catch us all.... heeheehee... I did say "most".... and im not dead yet... :biggrin:
Quote from: Millietant on December 06, 2018, 10:40:21 AM
Don't worry mate, it's not all roses here. We have cameras everywhere too, wether it's for security, speed, red light running...we even have coppers that sit in trees with radars on one of the popular mountain roads around the Brisbane area. Even at work they've introduced GPS trackers in everything, supposedly for our safety, as well as fingerprint scanners. Big brother has a good grip on you here and it's getting tighter.
Gee and I thought the People's Socialist Republic of Kalifornia was bad. You guys are really oppressed.
Ribz0, the exhaust IS really expensive, more so for you obviously. However two things pushed me into it. One, the aftermarket system that was in place had to be removed just to change the oil. Don't know what the designers were thinking. Two, the right side Givi bag would interfered with the muffler. I had to cobble up a really cheezy bracket just to make the RPM Fall Rally. So, eventually there is motivation. Good luck.
