General Category => Maintenance => Topic started by: Scottie1 on November 12, 2018, 01:53:55 AM
Title: Clean brake calipers seals
Post by: Scottie1 on November 12, 2018, 01:53:55 AM
I have taken apart the front brake calipers and took the seals off to replace with new ones. I have been cleaning and soaking the calipers in soapy water and using a toothbrush and a wooden tooth pick to clean the seal grooves but there is still some crud left that just won't come out. Is there a better way of doing this or a product I can use.
Title: Re: Clean brake calipers seals
Post by: red on November 12, 2018, 02:29:05 AM
Quote from: Scottie1 on November 12, 2018, 01:53:55 AMI have taken apart the front brake calipers and took the seals off to replace with new ones. I have been cleaning and soaking the calipers in soapy water and using a toothbrush and a wooden tooth pick to clean the seal grooves but there is still some crud left that just won't come out. Is there a better way of doing this or a product I can use.
Scottie,
Did you try Brake Cleaner, in an aerosol can?  You may want to wrap around the pistons inside the grooves with non-synthetic knitting yarn, or thin strips of cotton cloth, to hold the solvent in place for a time.
Post by: Scottie1 on November 12, 2018, 03:14:59 AM
Yeah I've tried brake cleaner even let it soak for a bit and it didn't really remove much. I have seen someone used a brass dremmel wheel but I don't really want to try that just Incase it scuffs up the inside.
Post by: ribbert on November 12, 2018, 07:55:28 AM
Quote from: Scottie1 on November 12, 2018, 03:14:59 AM
....I have seen someone used a brass dremmel wheel .....
Post by: ZOA NOM on November 12, 2018, 08:10:28 AM
Ever try Sea Foam? That shit is magic.
(https://proxy.duckduckgo.com/iu/?u=http%3A%2F%2Fwww.dimecitycycles.com%2Fmedia%2Fcatalog%2Fproduct%2Fcache%2F1%2Fimage%2F9df78eab33525d08d6e5fb8d27136e95%2F5%2F3%2F53-0170-seafoam-motor-treatment-16oz-1.jpg&f=1)
Post by: Scottie1 on November 12, 2018, 12:10:18 PM
Just soaked them in that and used a small tooth pick it's coming out. Thank you for letting me know Seafoam will do that.
Post by: CutterBill on November 16, 2018, 05:42:14 AM
Stainless steel wire wheel on a Dremel works great... very quick and easy. Never had a problem with fluid leakage; the seals seem to be very tolerant of any minor imperfections. Make sure the pistons are perfect; clean with scotchbrite pad.
Bill
Post by: TomJK on December 17, 2018, 09:57:10 AM
Quote from: CutterBill on November 16, 2018, 05:42:14 AM
Bill
Same here, used Dremel with softbrush and metalpolish, worked fine, see pic...
TomJk.
