General Category => General Discussion => Topic started by: roverfj1200 on August 05, 2018, 04:29:35 AM
Title: New to the stable
Post by: roverfj1200 on August 05, 2018, 04:29:35 AM
Just added this to the stable.. Needs a little work but all the good bits are there.
Title: Re: New to the stable
Post by: Troyskie on August 05, 2018, 04:32:13 AM
Niiiice one mate! :good2:
Check out the FB post with the 91 parts. There are forks etc...
Post by: Harvy on August 07, 2018, 12:06:57 AM
I bought this recently, but it will have to go..... just too much lean for my old wrists (unless of course I do a handle bar raise mod on it).
Post by: ribbert on August 07, 2018, 08:20:12 AM
cl
Quote from: Harvy on August 07, 2018, 12:06:57 AM
Yep, they sure are low Harvy. You must have like the bike to have bought it, so why not do the bar risers.
My son has been flying survey work all over the Outback the last couple of years. A few weeks back he came across a chopper crew and truck, and confidently marched up to the driver and asked him if he was Harvy and rode an FJ - he wasn't and he didn't.
He thinks they were replacing high vis styrene balls on power lines. Their set up was exactly as I had described yours to him Harvy.
Post by: red on August 07, 2018, 11:41:48 AM
Quote from: Harvy on August 07, 2018, 12:06:57 AMI bought this recently, but it will have to go..... just too much lean for my old wrists (unless of course I do a handle bar raise mod on it).
Harvy,
Instead of risers, I would suggest considering a change to standard handlebars.  Risers are just too limited in positions, compared to the endless possibilities you will have with regular handlebars.  Somebody makes a simple adapter plate for the FJ, and any normal handlebars will fit, if the steel tubing is the correct size for the handlebar clamps.  If the handlebar clamps are made for 1" bars, I could see using half-shell shims, to adapt the clamps for 7/8" diameter handlebars.   I have not changed my FJ over yet, but come the winter snows, I think I will.
My $.02 worth . . .
Post by: Pat Conlon on August 07, 2018, 01:36:16 PM
Spot on Red! :good2:
Sooooo many options becomes available with tubular bars
(https://cdn.spieglerusa.com/pub/media/product/43891654/handlebar-conversion-kit-yzf-1000-r-z120y070.jpg)
https://spieglerusa.com/controls/handlebar-conversion/handlebar-conversion-kit-4389.html
Post by: Harvy on August 07, 2018, 05:10:53 PM
Quote from: ribbert on August 07, 2018, 08:20:12 AM
cl
Hi Noel....yes mate, I got it pretty cheap and is in pretty good nick. Total different experience to the FJ.... these Genesis engines sure can rev!
Your son may have run into one of Aeropowers completion....was he in far north qld at the time?
I have retired so he will not find me out and about in the truck any more.
I may have come up with a solution for my wrists too.... as it's only my left wrist that gives me grief when operation clutch lever, rotating the lever downward a few degrees might just do the trick.
Hope to see you next March mate.... I'm all booked in.
Post by: ribbert on August 08, 2018, 02:59:48 AM
Quote from: Harvy on August 07, 2018, 05:10:53 PM
.... as it's only my left wrist that gives me grief .....
Hey Harvy, if it's only your left hand maybe a set of these as used on the autorace bikes in Japan would do the trick.
(https://i.redditmedia.com/8UIar67PrhKrJjvsW9tFBcigUIFoHZ62ctP3vMzC8Oc.jpg?fit=crop&crop=faces%2Centropy&arh=2&w=960&s=0671fc5f39b238fbd8b1e89fbb098e70)
Yes, it will be good to catch up at the Rally, looking forward to it.
