Looking for help to diagnose why the power , neutral light won't shut off when I turn the key off . Engine won't shut off either when key is turned off . Can kill engine with kill switch but fuel pump still on . Have to disconnect battery to disable power .
Clearly the ignition switch is shorted.
Quote from: ZOA NOM on May 21, 2018, 07:31:35 PM
That's the first place I would look, too.
I had this happend twice The first time one of the wiring from the tank had broken and shorted.Second time was when i replaced the red switch from alternator and managed to connect the wires opposite way.
