General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: aviationfred on March 24, 2018, 05:57:47 AM
Title: ABS service light stays on
Post by: aviationfred on March 24, 2018, 05:57:47 AM
I am hoping someone can tell me the quick remedy to get the ABS service light to not be on. I have removed 90% of my ABS system. The only part that remains are two brake lines for the rear brake and the rear ABS sensor in the rear wheel.
I have not had a chance to look at a wiring diagram yet. I have removed the ABS fuse, I figured that would keep the light from coming on.... Nope.
Title: Re: ABS service light stays on
Post by: oldktmdude on March 24, 2018, 06:01:55 AM
   Remove the light bulb. Guaranteed to never light up again!   :good2:
Post by: aviationfred on March 24, 2018, 07:02:29 AM
Quote from: oldktmdude on March 24, 2018, 06:01:55 AM
Can't argue with that.
Post by: TexasDave on March 24, 2018, 07:30:09 AM
Quote from: aviationfred on March 24, 2018, 07:02:29 AM
.22 cal would be about the right size and fastest.   :biggrin:
Post by: FJ1100mjk on March 24, 2018, 10:28:27 AM
Quote from: aviationfred on March 24, 2018, 05:57:47 AM
Remove bulb!!!???!!! Meh.
You want quick?...
(http://fjowners.com/gallery/10/1388_24_03_18_9_21_34.jpeg)
(http://fjowners.com/gallery/10/1388_24_03_18_9_22_34.jpeg)
You're welcome.
:Facepalm:
Post by: FJ_Hooligan on March 24, 2018, 02:23:29 PM
When I removed all the ABS electronics in the rear tail, the light never came on.
However, I never checked to see if the bulb was blown.
Post by: racerrad8 on March 24, 2018, 04:27:05 PM
I seem to recall removing two ABS fuses from the box. My bike has the complete system on it with the fuses removed. ABS does not function and there are no lights illuminated on the dash.
Post by: racerrad8 on March 24, 2018, 06:30:44 PM
Quote from: racerrad8 on March 24, 2018, 04:27:05 PM
I took out the "ECU" and "warning" fuses.
Post by: aviationfred on March 24, 2018, 06:34:49 PM
Quote from: FJ1100mjk on March 24, 2018, 10:28:27 AM
You want quick?...
You're welcome.
:Facepalm:
That is awesome.... definitely works without even needing to break out the tools.
Post by: aviationfred on March 24, 2018, 07:20:24 PM
The 3Amp warning fuse did the job, thanks Randy.
