General Category => FJ Parts / Service Vendors => Topic started by: Troyskie on December 30, 2017, 08:03:23 PM
Title: Renntec drop bars, engine protection
Post by: Troyskie on December 30, 2017, 08:03:23 PM
 :good2:
After a recent off I'd like to suggest the Renntec drop bars.
Here's a pic.
Accident was rider incompetence &
Bike was spinning latitudinally,  not endo. Was probably doing about 50km/hr (30mph) when it hit the ground.
The drop bars stopped any engine case damage.
They also make fine mounts for lights, camera, etc. They are also handy in the workshop.
Title: Re: Renntec drop bars, engine protection
Post by: Sparky84 on December 30, 2017, 10:50:04 PM
Quote from: Troyskie on December 30, 2017, 08:03:23 PM
I think they're handy in the workshop too but
I'm thinking it's time to fit them to my bike  :good2:
Those Renntec bars look almost unscathed.
Good to see the Aldi gear worked also.
Looks your filling in your time Troy
Cheers Alan
Post by: racerrad8 on December 31, 2017, 02:09:20 PM
There are two different engine bars which are dependent of the year model FJ you have.
84-90 FJ Engine Bar Set (http://www.rpmracingca.com/proddetail.asp?prod=84-90FJEB)
91+ FJ Engine Bar Set (http://www.rpmracingca.com/proddetail.asp?prod=91-93FJEB)
They do work great. I know of one forum member who has tested his set out three or four times. Each time there has not been any engine damage sustained.
Thanks for the mention Troy, I'm glad they worked well on your FJ. Based on those photos of you injury, you will no longer be able to get through airport security very easily...
Follow the doctors orders and take the proper time to heal, it will benefit you more in the long run over rushing it.
Post by: FJmonkey on December 31, 2017, 02:33:57 PM
Yep, I was present for 3 of the field tests from one owner (same set of bars) and the FJ was ridden home by the owner (proper gear for rider and bike). He did mention needing to weld up a few thin spots. I can also attest personally to the benefits from a low speed drop and a few zero speed tip overs.  :blush:
Post by: FJ Flyer on January 04, 2018, 01:16:39 PM
Saved my engine during a 20+ yard slide down the highway about 12 years back.
(http://fjowners.com/gallery/46_08_10_09_5_11_54.jpeg)
Post by: Troyskie on January 04, 2018, 07:55:32 PM
 :good2:
Post by: Charlie-brm on October 19, 2018, 09:53:41 AM
Do the bars make raising a dropped bike any easier? To keep the scenario simple: dropped on level asphalt, is the bike laying at a slightly higher angle so getting started to upright it is any less initial grunt?
Post by: FJmonkey on October 19, 2018, 10:45:19 AM
The bars did not seem to help much when I picked mine up. But the ability to ride it after, was worth the investment.
Post by: Troyskie on October 19, 2018, 10:37:24 PM
I overbalanced once at a petrol station. A slow and gentle lay-over, I managed to kick the rear peg out and made sure the handlebar was turned to straight, the drop bars kept everything off the ground. There were three points of contact, the drop bar, rear peg, and the tip of the handlebar. The Renntec made it a little harder to get started, but easier once moving as it acted like a fulcrum till the wheels took over. Aside from a tiny nick on the bars, not a mark on the bike, including the mufflers!!!!
If you're struggling to lift a bike, turn around, squat, and lift with the bike behind you till it is upright enough so you can turn around whilst keeping it steady. I saw a YT vid, I think from the forum, of a lass lifting a BMW. I tried it myself for laughs after a workshop whoopsie (the not so funny part) & yep, much easier, but you do have to think about it a little more, and go a bit slower.
Post by: Sparky84 on November 20, 2018, 07:06:45 PM
:good2:
Had a look at mine (that aren't fitted) to fit and they seem to rest up against part of the lower frame, Will this over time get rub marks and how could I stop this.
Also looks to rub on the centre bracket and can I stop this damage
Cheers Alan
Post by: Troyskie on December 01, 2018, 05:38:26 AM
Al, I fit them to all my bikes as I'm an idiot and they don't wait for me to be stupid, they are ready.
That also prepares me for a-holes that  try everyday to .......whatever......
