General Category => Maintenance => Topic started by: HydroDog on November 19, 2017, 03:05:18 PM
Title: Keyster Carb Rebuild kit
Post by: HydroDog on November 19, 2017, 03:05:18 PM
Hello All,
I'm rebuilding my carbs for my 84' and i'm in the process of reassembling them. I went to install the emulsion tube to find out it is smaller than the stock tube.  :scratch_one-s_head:
So I measured them and the old tube measured .3380" and the new one ( I have not opened the other 3 kits) measured .03347".   I'm not a carb rebuild genius, but I do realize that fuel will be pulled up past that clearance and not go through the main jet.
The old ones, I machined up a driver to tap them out. With the new ones, they fall right in; which is very convenient but I doubt it's right.
Has anyone else had this problem, and what did you do?
  Just install and hope the washer under the main jet does the sealing? Loctite? Put the old ones back in?
John
Title: Re: Keyster Carb Rebuild kit
Post by: FJmonkey on November 19, 2017, 03:14:56 PM
Check with the Carb experts at RPM. Click on banner above. But if you are using an after market kit, they will likely offer you the correct OEM parts. They fix a lot of carbs because of after market kits.
Post by: HydroDog on November 19, 2017, 09:47:50 PM
Well, opened the second kit and it's the same way. :bad:
Post by: balky1 on November 20, 2017, 12:28:17 AM
If the hole where needle goes is not oval, your emulsion tubes are good. Clean them well, all holes must be clean, and put them back. Clean the gunk out of their seats, too. They'll go back much easier than out.
Post by: HydroDog on November 20, 2017, 02:45:08 AM
Quote from: balky1 on November 20, 2017, 12:28:17 AM
I ended up machining a pin gauge to check the bore that the needle passes through. So far all is good with the old ones so I have been reusing them.
Post by: balky1 on November 20, 2017, 10:53:18 AM
OK, great.
I had some problems with Keyster also. So I don't know what to say about their products...  :negative:
Post by: HydroDog on November 20, 2017, 11:06:49 PM
I received a message from RPM today and the  Keyster emulsion tubes are good to go, so I'll be installing them. Yea.
Post by: balky1 on November 21, 2017, 12:20:25 AM
OK, good luck!
I bought needle seats with needles some two years ago from Keyster. Although they work perfectly since, I did notice a slight difference from OEMs and I had a professional to tune the floats afterwards since I couldn't do it.
