General Category => Maintenance => Topic started by: Country Joe on August 13, 2017, 03:10:17 PM
Title: Valve shim calculator
Post by: Country Joe on August 13, 2017, 03:10:17 PM
Just wanted to share this valve shim calculator that i found yesterday. Makes figuring out your new shim thickness a piece of cake.
http://www.maultechatv.com/techguides/Valve%20Clearance%20Calculator/ (http://www.maultechatv.com/techguides/Valve%20Clearance%20Calculator/)
Title: Re: Valve shim calculator
Post by: FJmonkey on August 13, 2017, 03:27:10 PM
It seems to provide the ideal shim size. But shims do not come in ideal sizes. However, it is just a calculator and knowing that a loose valve is happier than a tight valve this can be a good tool for any adjusting their valves.  Thanks for sharing your find.
