General Category => Modifications => Topic started by: camo on April 03, 2017, 11:12:29 PM
Title: Honda clutch M/C conversion: Do you need a new clutch line?
Post by: camo on April 03, 2017, 11:12:29 PM
Hey all,
i had a look thru the forum and couldnt find anything definitive so though I would check. Im in the process of converting my M/C over from Yam to the Honda VFR ones. I note the honda banjo bolts are orientated 90deg. differently than the yamaha ones and to hook up the Yam clutch lines means a fair bit of strain on the lines. Have people who have done this conversion needed to purchase a custom made clutch line? I figure as the current line is 25yo its worth replacing..
Thanks in advance.
Camo
Title: Re: Honda clutch M/C conversion: Do you need a new clutch line?
Post by: jscgdunn on April 04, 2017, 02:43:09 PM
I have VFR MC on mine and they work great.  Lines have been replaced.
Post by: aviationfred on April 04, 2017, 09:01:32 PM
Here is the link to my Honda VFR clutch master cylinder install
http://www.fjowners.com/index.php?topic=9635.0 (http://www.fjowners.com/index.php?topic=9635.0)
I would highly recommend the FJ1200 Spiegler clutch line. I use it with my Honda VFR800 clutch master cylinder and it works great. The banjo fitting ends can be rotated to account for the difference in the connecting point.
http://rpmracingca.com/proddetail.asp?prod=S-YA0145&cat=39 (http://rpmracingca.com/proddetail.asp?prod=S-YA0145&cat=39)
