General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: Mike m on April 02, 2017, 12:06:30 PM
Title: Case has crack
Post by: Mike m on April 02, 2017, 12:06:30 PM
Can this be jb welded.is this a stress area :Facepalm:
Title: Re: Case has crack
Post by: Earl Svorks on April 02, 2017, 01:12:16 PM
  Hey Mike,
That's a nasty crack. I don't think there's much point in trying to glue it up. I'd be more concerned about what forces were at work to cause that in the first place. Have the cases ever been apart ? I wonder if the steel dowel in that hole was too long? To fix that break, I would think the cases would need to be split, then the crack prepped then TIG welded. In the mean time, I think you could just leave it as it is. I doubt that you'll get any leakage and the actual crack can't get any worse.  Other opinions may differ as I'm sure we'll see.
 Simon
Post by: FJmonkey on April 02, 2017, 01:52:33 PM
That cracked boss is not a real problem as long as no oil is leaking. A cold weld or bond is not likely to gain much. The crack is dirty/oily and if you can't get it clean then any bonding material will not stick. A proper fix is TIG welding with the cases split. If it is not leaking oil then just keep an eye on it.
Post by: Mike m on April 02, 2017, 03:01:02 PM
Idk if my case has been apart.how can I tell?
Post by: simi_ed on April 02, 2017, 03:28:04 PM
Don't bother with JB Weld. This needs to be welded to do anything.  You might as well use chewing gun, it'll have the same effect (0).  Is this actually leaking?  You need to clean & inspect this carefully.  If it is the beginning (or worse, the tail end!) of a crack you got major worries.  I'd bet that is not the case, however.
My 2ยข
Post by: Mike m on April 02, 2017, 04:16:51 PM
So all the members here with fj 1100,1200 have never seen this issue correct?
Post by: X-Ray on April 02, 2017, 05:38:46 PM
I've got to say that is a new one to me Mike.
Post by: Urban_Legend on April 02, 2017, 05:45:47 PM
I just had a look at my FJ11. No crack, but did notice a cast line there, which your crack seems to follow. This cast line would be a weak point, but I have never heard of it cracking before. I would say that it has been overtightened by a PO. Keep an eye on it for oil seepage. It will be hard to ignore now that you know it is there.
Mark
Post by: Mike m on April 02, 2017, 05:50:17 PM
 :diablo:
