General Category => Parts Wanted => Topic started by: fjsforever on December 30, 2016, 06:31:48 PM
Title: Found****Looking for a nice '87 FJ1200 fuel tank
Post by: fjsforever on December 30, 2016, 06:31:48 PM
Looking for a nice tank for an '87 model FJ1200. Must have good/excellent original paint, no or little rust. Tks!
Title: Re: Looking for a nice '87 FJ1200 fuel tank
Post by: FJmonkey on December 30, 2016, 08:50:13 PM
What you seek will not be easy to find. More likely in a poor to usable condition. But good condition bikes still get found, you may get lucky.
Post by: CutterBill on December 30, 2016, 10:12:42 PM
Quote from: fjsforever on December 30, 2016, 06:31:48 PM
Yeah, and I want Gigi Hadid to serve me breakfast.  Not gonna happen...    :rofl2:
Post by: aviationfred on December 30, 2016, 10:33:31 PM
The 1987 bodywork parts are about the most difficult to find. My suggestion is to set up a notification search on eBay. About the only other suggestion would be to find a '86/'87 tank in not so perfect shape and re-paint to the factory colors.
Post by: ribbert on December 31, 2016, 04:12:47 AM
....and pigs refuelled and ready for takeoff.
It's always worth asking but unfortunately your quest is unlikely to be fruitful. You might get lucky elsewhere but I would not be relying on it. Good tanks are like hens teeth and anyone here who happened to have one would not be parting with it.
You would do best to follow the advice already given, restore and repaint your existing tank. Yes, a pristine replacement tank would be nice, but it ain't gonna happen. The odds on finding one for sale in the condition you describe are about the same as winning the lottery.
But, stranger things have happened and it's worth throwing out there, just don't hold your breath.
Post by: giantkiller on December 31, 2016, 08:00:35 AM
Aren't 86 and up all the same, other than color and petcock. Niether of which matter. If you repaint it.
If you widen your search. For all years and are patient. You might get one. Both I and my brother found tanks in a matter of a couple of months. Mine is shiny clean inside. Just the wrong color. For $100.
For that matter. Wouldn't the 84-85 tanks work, just a different lid. And slightly more capacity? Because of the lid not being counter sunk.
Post by: giantkiller on December 31, 2016, 08:33:18 AM
This is the tank that came on the bike I bought to make the turbo bike. The tank looked fine, from the outside. Was totally perforated on the bottom. Could blast the inside. And make a new bottom plate and weld it in easy enough. Or if someone could find a tank from a newer bike( that has a cosmetic cover) that fits. Or even a plastic tank from an ATV/dirt bike. Even better. Would never rust. You could use the Fj tank for the cover. Or take a mold off the Fj tank and make a cover out of carbon fiber. Or just fiber glass. (Which is what I was going to do. When the pristine tank, in the wrong color appeared for $100)
Post by: weymouth399 on December 31, 2016, 09:04:22 AM
Couple of things to consider here. In 85-88 in America Yamahas sales tanked. They weren't selling bikes like they wanted  that's why you don't see 88 Yamahas in America. It was the full line that had this issue. Because of this a lot of these 85-88 bones were in crates for years, some were not sold till the 89-90. The fuel tanks were rusty before they left the dealership lots. I did many tank flushes on brand new bikes back then. So yes finding a mint tank will be very hard to do on this continent. And 87s were different colors in other parts of the world. If I can't get a title for my 87 to sell to a guy in NC I will have pretty nice one that's been creamed, and a ton of nice parts 24k mi bike. Hate to part it.
Bob w
Post by: aviationfred on December 31, 2016, 10:15:31 AM
Quote from: giantkiller on December 31, 2016, 08:00:35 AM
To answer this question and info for the original poster. No the tanks are not the same. The 1986/1987 tanks and petcocks are the same. The 1988-1996 tanks and petcocks are the same.
The main difference is..... The 1986/1987 tanks use a vacuum actuated petcock. The 1988-1996 tanks have a free flow petcock. You can not have a 1989 tank and install a 1987 petcock. The actual hole in the tank and screw holes are not the same dimension.
You can use a 1988-1996 tank on a 1986/1987, using the standard OEM petcock as long as you install an inline manual ball valve that you will HAVE TO close every time you park the bike. If you don't close the ball valve, there is nothing keeping the fuel from potentially getting through the carbs and filling your crank case with fuel.
Adding a fuel pump to the 1986/1987 models would also solve the problem of using a later model tank.
Another option would be a late model tank w/standard petcock and install a secondary aftermarket vacuum actuated petcock.
Post by: JMR on December 31, 2016, 01:09:32 PM
Quote from: aviationfred on December 31, 2016, 10:15:31 AM
I have used this Pingel inline vacuum valve for years. http://www.pingelonline.com/pc_product_detail.asp?key=3CCC32F0434D41F0B6C89EC32D85EB11 (http://www.pingelonline.com/pc_product_detail.asp?key=3CCC32F0434D41F0B6C89EC32D85EB11)   It supplies enough fuel fuel for FCR-39's and is very reliable.
Post by: FJmonkey on December 31, 2016, 01:20:39 PM
I have a spare '89+ tank that was stripped and the interior coated. I consider the tanks condition as rough and needs a proper recondition. If interested send me a PM.
Post by: fjsforever on December 31, 2016, 08:43:52 PM
Thanks for all the info guys but I blew an opportunity for an NOS '87 tank months ago on Craigs....$300 (sobbing!). Now, of course, I recently obtained an '87 that could use one...
Post by: giantkiller on December 31, 2016, 10:41:08 PM
Or just put the pingel manual one on. And bend bend the screen on the top slot of the side panel down for access. And not worry about the petcock. I made my first plate for a pingel imitation. That started leaking. At the West coast rally. So I purchased a real pingel from Randy. That Robert Installed for me while I waited. Thanks again.
I have an 87 tank. But it's been empty since 87 and has alot of rust inside. From sitting empty.
Post by: fjsforever on January 01, 2017, 04:55:29 PM
Quote from: giantkiller on December 31, 2016, 10:41:08 PM
If you're willing to part with it I may be interested....How extensive is the rust?...any pics? LMK
Post by: krusty on January 02, 2017, 12:32:27 AM
Nice, but shipping would be a budget killer.
http://www.ebay.com.au/itm/FJ1200-fuel-tank-/282310180657?hash=item41baff7f31:g:D9gAAOSwa~BYS8J1 (http://www.ebay.com.au/itm/FJ1200-fuel-tank-/282310180657?hash=item41baff7f31:g:D9gAAOSwa~BYS8J1)
Post by: giantkiller on January 02, 2017, 10:51:23 AM
Quote from: fjsforever on January 01, 2017, 04:55:29 PM
I was In reference to Bob W. Post about new leftover bikes having rusty tanks. And lack of 87s. It has alot of rust inside. Due to sitting empty.. That's why I was looking for another alternative for the turbo bike. And found the one (wrong color) for$100. Still going to look for a tank to go under Fj shell in the future. Would solve all the rusty tank problems.
Post by: fjsforever on January 18, 2017, 01:35:34 PM
Found it...Thanks!
