General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: aj52 on December 12, 2016, 12:41:40 AM
Title: Clutch slipping after rear wheel swap
Post by: aj52 on December 12, 2016, 12:41:40 AM
Happy with handling after rear wheel slip.
Took bike on a sunday afternoon trip off about 150km to test it through some curves.
On my way home,I opened throttle a bit and clutch starts to slip :shout:
Slowed down and open it again full throttle,slips again.
Ride home at 140km/h,very pissed and parked bike.
I have read the clutch files what to do to solve the problem.
My question: Is there any special tool that is needed to do clutch work?
Hannes
Title: Re: Clutch slipping after rear wheel swap
Post by: Pat Conlon on December 12, 2016, 01:38:42 AM
Nope
Post by: Old Rider on December 12, 2016, 01:39:24 AM
I guess you already know but if you have changed motoroil lately its important that you use a motorcycle motor oil.If you use a synthetic based oil not made for motorcycle with clutch and gearbox bathing in the oil you might experience slipping clutch.I can recomend yamaha lube semisynth.
Post by: movenon on December 12, 2016, 03:43:29 AM
Pretty easy to do. Here is a good read. http://www.fjowners.com/index.php?topic=1808.0. (http://www.fjowners.com/index.php?topic=1808.0.)  You don't even need to drain the oil if the bike is on it's side stand. You might consider having a new clutch cover gasket on hand along with the clutch disks and steels if you need them.
Post by: aj52 on December 12, 2016, 03:45:49 AM
Quote from: Old Rider on December 12, 2016, 01:39:24 AM
Thanks for the reply,but no,I didn't change oil after wheel swap.
Bike run Castrol 4T motorcycle oil in it.
It had slippich about 5000km back caused by wrong oil,but since I ran the Castrol,this is the first time.
If I accelerate normally,it is fine. It slip under hard acceleration
Post by: aj52 on December 12, 2016, 03:50:26 AM
Quote from: movenon on December 12, 2016, 03:43:29 AM
Thanks George
I had read this same thread this morning.
I just want to know if there is any special tools involved.
Pat answered me on that
If I get trouble a long the line,I will ask for help with it
Post by: Motofun on December 12, 2016, 04:06:05 PM
If the engine has been worked on, ie stage 3 kit etc, you may need to add an additional clutch diaphragm spring.  I did this to me '85. the clutch pull is that much harder, I put the FJR Master cyclinder on it and it helped some, but still requires an added effort.
Post by: bigbore2 on December 14, 2016, 10:37:39 PM
a new clutch spring should do the trick.  But while your in there.......upgrade.
Post by: JOMPPA10 on December 18, 2016, 04:58:37 AM
Quote from: aj52 on December 12, 2016, 12:41:40 AM
Hannes
hi how old are your clutch plates, because mine started to slip suddenly..
Seppo
