89 FJ1200 speedo is bouncing around 7mph above and below what it should actually read. I just put a new speedo cable (inner and outer) on it. Starts doing it around 40ish mph and gets worse as you go up. If it is bouncing and I pull the clutch in and just coast it smooths right out and stays right on the mph it should be on. What should my next step be? Do I dare try the gear at the wheel or do I need to replace/fix the instrument cluster? It isn't making any noise I don't think, but I did just recently purchase the bike so knowing what noises should be there and shouldn't isn't my strong suit yet. In some of the threads I have read on this issue there was mention of a place I could send the cluster to get it repaired. If this is the route I need to take what is the name of that repair shop? I couldn't find the name only mention of it.
Thank you for any help,
Benjamin
I have the same issue so I'm going to watch this. But make sure the new cable has plenty of grease and that there is no sharp bends in it. Mine is aggrivaTed over bumps so I'm going to grease mine first
Your speedo is likely to bounce like a 5 year old on 2 shots of espresso. My '86 did this, then it did it again with an '84 speedo installed. My '89 does it. Fred (Avationfred) found a digital solution that fits in the dash. I just use my GPS...
So there really isn't a fix? :shok: It really is annoying!! Why would it go smooth when I pull the clutch in?
Quote from: AgPilot on August 08, 2016, 07:31:50 PM
Ok, you got me, there is a shop in San Diego, CA that will rebuild them. Simi_Ed had his rebuilt and was pleased with the work. Your clutch has nothing to do with the speedo function other than speed control. Without going into the depth of permanent magnets, the spin of the cable and a coil spring the bushings/bearings wear out. Simple as that. Certain speeds will cause harmonics and the speedo will bounce. The cable and cable shroud can also affect this but if properly lubed and not damaged then the speedo will eventually sound like a scalded cat (AKA "death howl" of the speedo).
The 3 components of your speedometer system are 1) the gear drive at the rim 2) the cable and 3) the speedo unit itself.
1) The gear drive is pretty much indestructable if kept properly greased. That said, I have read a post recently about a failure on the gear drive.
2) The cable is the same, if kept properly lubricated.
3) The speedo unit. The lubrication in the speedo unit dies out after a number of years causing wear and slop on the plastic gear bushing first, then once the shaft is out of alignment the gears themselves. The symptoms are: first the needle bounce, then the whine, then the howl, then total failure. You can try adding lubricant but in my experience you are just forestalling the inevitable. Once the bushing is worn, it needs replacement. Once the gears howl, they need replacement.
I just had my '84 speedo rebuilt ($125) by these guys: http://www.foreignspeedoinc.com/ (http://www.foreignspeedoinc.com/)
Foreign Speedo Inc.
2246 1/2 University Ave.
San Diego, Ca. 92104
619-298-5278
Good guys. Send the entire cluster in to them. They tell me they charge extra if the speedo unit is opened and tampered with...I'm sure they were kidding. ?
FYI, This info is saved in the General Maintenence Files: http://www.fjowners.com/index.php?topic=5718.0 (http://www.fjowners.com/index.php?topic=5718.0)
With the cluster out, it's a good time to replace your lamps or convert over to LEDs.
Hope this helps. Pat
Is the rebuild a fix fix or just kind of a doesn't jump as much fix? I totally agree that the clutch has nothing to do with the operation of the speedo, but I can make it stop and start bouncing by working my clutch every time. That's the part that seems just odd to me.
And thank you guys for the knowledge, really do appreciate it!!!! :good2:
Quote from: AgPilot on August 08, 2016, 07:49:17 PM
Any change that affects the harmonics can cause this. It is odd till you understand harmonics. Why do two similar buildings (Size, shape etc...) have two different outcomes in an earthquake? Find the natural frequency of an object/assembly and you can destroy it. Shatter a wine glass just from sound....
Thank you Monkey and Conlon, I will look into that shop.
AgPilot,
The clutch aspect is puzzling, no doubt! Sharp bends in the cable or some lack of lubrication inside are the usual causes. From the speedo to the spokes, the cable should be as straight as possible, and all bends in the cable should be close to the wheel hub. Try tying the cable to the framework, to keep it very straight near the speedo end. If that does the job, install some Ty-Wraps instead of string as a more permanent fix. I can't imagine the instrument causing this, so I'd like to hear what the right fix will be, when you get it.
Happy hunting,
It is as straight as possible and greased. I will try securing it better and see if there is a difference.
Interesting. I have similar prob on my '85. It doesn't bounce constantly, but if I ride it continuously for an hour-hour and a half then starts bouncing whenever I get over some bumps. So I figured out it has something to do with forks stretching and compressing as it straightens or bends the cable that way. I lubed the gear and cable with no change and just left it like that.
Quote from: balky1 on August 09, 2016, 01:48:41 AM
Balky, I think you'll find it's just the bumps, not the cable bending as the forks compress. If you hold a speedo in your hand and move it down and up quickly the needle will rise and fall. If it's lost some of its damping, it will jump over bumps.
Quote from: AgPilot on August 08, 2016, 08:22:31 PM
The best routing for the cable is as it naturally falls from the speedo to the wheel, tying it to something is more likely to cause a kink.
Quote from: ribbert on August 09, 2016, 08:36:56 AM
Thx for input Noel. It doesn't worry me too much, I try not to watch it anyway. :rofl2:
I found the cable was causing mine - but it only happened around the 110kmh mark and cleared up as you hit 130Kmh (allegedly officer)
New cable cured it but I don't think this sounds like your problem.........
GPS speedo from Speedhut fixed my bouncing needle. Not cheap but better than an expensive speeding fine.
Quote from: oldktmdude on August 10, 2016, 12:50:17 AM
For $100 I got a GPS/HUD speedo that projects my speed onto the inside of the shield, I love it.
Quote from: ribbert on August 10, 2016, 06:55:23 AMQuote from: oldktmdude on August 10, 2016, 12:50:17 AMGPS speedo from Speedhut fixed my bouncing needle. Not cheap but better than an expensive speeding fine.
Noel,
Hey, links, man, links! Can't just hit-and-run like that! :biggrin:
Okay, now this lil black box runs as HUD or read it straight, as you may wish, and costs a breath-taking US$38. Rapid updating and Very accurate. (Free shipping on Amazon orders over US$49.)
https://www.amazon.com/Kingneed-Vehicle-Head-Up-Speedometer-distance/dp/B0148JUT7W/ref=lp_3032928011_1_1?srs=3032928011&ie=UTF8&qid=1470838434&sr=8-1 (https://www.amazon.com/Kingneed-Vehicle-Head-Up-Speedometer-distance/dp/B0148JUT7W/ref=lp_3032928011_1_1?srs=3032928011&ie=UTF8&qid=1470838434&sr=8-1)
Quote from: red on August 10, 2016, 09:25:07 AM
I just ordered one, I will post up when I have it installed. Great find, thanks Red.
I know that this is off topic, but do you guys know of any way to test the tachometer. mine doesn't work at all and all of my other gauges work just fine. I currently have the cluster off of the the bike.
Quote from: barberman91 on August 27, 2016, 10:39:29 PM
Just to clarify, tachometer is the RPM part? I know it sounds silly, but in Europe tachograf is a paper that records your speed in larger trucks and, hence, many call the speedometer tachometer.
Yep it's the rpm gauge
Quote from: balky1 on August 28, 2016, 02:56:32 AMJust to clarify, tachometer is the RPM part? I know it sounds silly, but in Europe tachograf is a paper that records your speed in larger trucks and, hence, many call the speedometer tachometer.
Balky1,
In the USA, the Speedometer gives the vehicle speed along the road.
The tachometer gives the engine speed, as RPM.
I can only tell about the 84/85 model, orange wire is connected to the #1 and #4 coil trigger coming from the TCI, light brown is 12 volts and black is ground. All three wires go through the 9 pin connector first. The black wire detours to the headlamp socket then back to the 14 pin connector with the orange and light brown wire. The fuel gauge shares the same 12 volts and ground along with the fuel, oil, neutral and high beam annunciators. Check resistance between the orange wire at the coil connector and the orange wire at the orange tach wire. Resistance should be less than 1 ohm.
Chris
