I just put a v&h on my 86 1200. I don't have a center stand stop installed. Is there going to be a big issue with not having it?
Quote from: a.graham52 on June 13, 2016, 06:51:44 AM
Take the center stand and move it up and down as if you are hitting large bumps. Does it crash into anything you don't want hammered over time? I am still youing with the idea of adding a magnet to help hold the CS up now that the spring is weak with age and use.
Yeah, you can lean way over without dragging the stand. :good2:
Quote from: Mark Olson on June 13, 2016, 10:13:31 PM
Yea, lean over so far you can hug your FJ from underneath it. :biggrin:
