General Category => Maintenance => Topic started by: Shane4371 on May 22, 2016, 07:42:54 AM
Title: Ii gotta chug now?
Post by: Shane4371 on May 22, 2016, 07:42:54 AM
Installed pilot jet 40,finally lifted my needle jet,now i gotta chug.surg at low speed not horri le but its thier,any ideas?
Title: Re: Ii gotta chug now?
Post by: FJmonkey on May 22, 2016, 09:34:59 AM
You changed two things, larger pilot jets and raised the needles. I doubt its the #40 jets and the needles are easy to put back where they were without removing the carbs. When trouble shooting, it is good to make only one change at a time. So try the needles back where they were and see if the "chug.surg" is affected.
Post by: fj1289 on May 22, 2016, 09:55:16 AM
I think you'll also need to adjust the idle mixture for the new pilots -- do that first since it will overlap with the other adjustment you are making
Post by: Pat Conlon on May 22, 2016, 11:11:05 AM
yep, it's fat.
Post by: Shane4371 on May 22, 2016, 03:35:37 PM
Very fat,can't I run them in.I'm at 3 turns out,
Post by: jscgdunn on May 22, 2016, 03:43:43 PM
Yes try turning them in at 1/2 turn incrments
Post by: Shane4371 on May 22, 2016, 04:02:55 PM
Will do,thanks
Post by: Shane4371 on May 22, 2016, 05:28:02 PM
I went 1/2 turn on each carb,rode it,no chug,then I went another 1/2 turn pinging on hard acceleration.going back 1/4 turn see what happens
