General Category => Modifications => Topic started by: Shane4371 on May 13, 2016, 05:48:11 AM
Title: Clutch master cylinder
Post by: Shane4371 on May 13, 2016, 05:48:11 AM
Please advise,what year FJR will fit my 86?
Title: Re: Clutch master cylinder
Post by: 4everFJ on May 13, 2016, 06:26:40 AM
I have used one from a 2001-2002 (RP04), so that definitely will fit.
Post by: Shane4371 on May 13, 2016, 05:07:09 PM
What is RPO4?
Post by: 4everFJ on May 13, 2016, 05:15:50 PM
The model.
Post by: wainot-Phil on May 13, 2016, 05:33:37 PM
I put a XJR1300  2004 Model  Brake and clutch master on my 85  fj1100
And
A  2010  model XJR1300  Brake and clutch Master cylinders on my 1994 FJ1200
fitted straight on...  and work great
Post by: CutterBill on May 14, 2016, 07:58:21 AM
Quote from: Shane4371 on May 13, 2016, 05:48:11 AM
I'm just curious... why not simply use the stock master cylinder?  They are still available from Yamaha.
Post by: Shane4371 on May 14, 2016, 08:54:49 PM
All I seen was part obsolete for 86 fj,I rebuilt mine today.a little Emory cloth so far so good.
Post by: CutterBill on May 14, 2016, 10:15:21 PM
Quote from: Shane4371 on May 14, 2016, 08:54:49 PM
All I seen was part obsolete for 86 fj...
Interesting.  Checking the parts catalog shows that the clutch master for an '86 is indeed obsolete, but the master for a '92 is still available... $116.  I wonder what the difference is.  They both take the same rebuild kit.  Hmmm...
Post by: Shane4371 on May 14, 2016, 10:20:40 PM
Idk so I rebuilt mine,I replaced clutch,slave,now rebuilt master.fur will fit.if this rebuild don't last
Post by: Shane4371 on May 14, 2016, 10:21:36 PM
92 maybe ABS?
Post by: CutterBill on May 14, 2016, 10:26:58 PM
ABS and non/ABS take the same clutch master.  I may have to dig my '85 clutch master out of the box and compare it to my '92 master.  Tomorrow; not tonight...
Post by: Shane4371 on May 14, 2016, 10:29:06 PM
 :good2:
Post by: Shane4371 on May 14, 2016, 11:39:44 PM
I agree,don't over do it.seals will leak with heating from over packing.co workers and I disagree on bearings also.some use grease to prelude oil bathed bearings.I say no.grease has a resistance to move which can starve a bearing of its designed fluid ultimate bearing seizure.
Post by: Hemi Bob on May 15, 2016, 12:26:28 PM
I got a brand new Yamaha clutch master from Partzilla PN# 3BV-26450-10-00 for an 89 $115.00
Used it as a replacement on my 85. The bolts that hold the leaver on is  not available but Fastenal order me some for 2 bucks
The only mounting issue is the old one had a tab that keeps the master and the signal switch pod connected
a bit of black RTV sealant between the two and it fine .
Bob
Post by: Shane4371 on May 15, 2016, 01:03:09 PM
Thanks Bob. :good2:
