So, now that I'm tearing into my father's bike, iv found the #4 carb has seized. Corrosion started from water entering the throttle shaft and corroding all around the butterfly. I let it soak for 2 days and today ended up bending the blade. What years will work on an 86 fj?
84 to 87 are gravity feed and are bolt on, 89 to 90+ can be converted to gravity feed, Randy has the parts.
Quote from: FJmonkey on April 13, 2016, 09:05:57 PM
Is it a big deal to convert? I can only seem to find 91+ carbs on ebay. What about 1100? Would those be ok?
Hi a.graham52.
1984-1985 are FJ1000's and their carbs will work as they are gravity fed. To convert pump fed carbs, you need to replace the T between carbs 2 and 3 with one of these:
http://rpmracingca.com/proddetail.asp?prod=Carb%3ACarbFitting&cat=39 (http://rpmracingca.com/proddetail.asp?prod=Carb%3ACarbFitting&cat=39)
Quote from: Tor-King on April 13, 2016, 09:27:23 PM
Hi a.graham52.
The needle and seat valves are different with a fuel pump (smaller opening). Here is a link that might help. RPM also has those.http://www.fjowners.com/index.php?topic=5150.msg93596#msg93596 (http://www.fjowners.com/index.php?topic=5150.msg93596#msg93596)
Quote from: a.graham52 on April 13, 2016, 09:09:56 PM
You will need to break down the late model carbs to install the dual 10mm inlet tees between 1/2 & 3/4 carb banks. You can either cap the stock center tee or you can install the conversion fitting I manufacture:
Carb Conversion Fitting (http://www.rpmracingca.com/proddetail.asp?prod=Carb%3ACarbFitting)
As already mentioned as well, you need to install the larger needle seats for the floats.
Googleypants, a search engine (http://www.rpmracingca.com/proddetail.asp?prod=Carb%3AFloatValveG)
Needle & Seat Assy (2.3) (Gravity) OEM Yamaha (http://www.rpmracingca.com/proddetail.asp?prod=3CF-14107-23)
Now, 1100's will bolt on but I have found they do not work well with the 1200 or larger bore engines. I could not make Pat's original flat bottom slide carbs run on the 1350 several years ago so a new set of converted 1200 carbs went on.
Quote from: racerrad8 on April 14, 2016, 10:59:35 AM
You will need to break down the late model carbs to install the dual 10mm inlet tees between 1/2 & 3/4 carb banks. You can either cap the stock center tee or you can install the conversion fitting I manufacture: Carb Conversion Fitting (http://www.rpmracingca.com/proddetail.asp?prod=Carb%3ACarbFitting)
Randy, I just ordered rebuild kits from you. Any chance I could send them back and get credit if the owner of my money gives me the OK on new carbs?
Quote from: a.graham52 on April 14, 2016, 02:24:53 PM
Sure thing.
Just let me know via email.
