General Category => Maintenance => Topic started by: Neoday2 on February 10, 2016, 08:12:41 AM
Title: Stainless Steel brake lines (front) and LSL bar risers - will stock length fit?
Post by: Neoday2 on February 10, 2016, 08:12:41 AM
Hello,
My FJ has the LSL bar risers and a stainless brake line from the bar to the splitter. I want to replace the rubber lines from the splitter to the calipers.  Most people (and kits) are for two brake lines and a new double banjo from the brake MC.
My question is this- for those of you with SS lines and bar risers- did  you have to get longer SS lines?  Or did the stock lengths work?
I am open to keeping the splitter or running two separate lines.
Title: Re: Stainless Steel brake lines (front) and LSL bar risers - will stock length fit?
Post by: moparman70 on February 10, 2016, 09:44:24 AM
I have risers on my 90 and put a set on that I purchased for an 86 -- just two lines so it eliminated the splitter.   They were stock length for the 86 and   have been working out fine without the extra length.
sc2
Post by: FJmonkey on February 10, 2016, 11:02:46 AM
You could get some hose/tubing about the same diameter as the brake line, route it and measure. That way you can compare if the stock lines will fit.
Post by: aviationfred on February 10, 2016, 11:53:45 AM
RPM is a Spiegler distributor. They sell both the LSL handle bar conversion kit and Spiegler stainless steel lines. Send Randy an email through the RPM website and ask him about line length.
Post by: bikemad on February 10, 2016, 05:17:56 PM
I use "Venhill" from the UK.
They supply braided lines in any lengths required in 25mm increments.
You can also order a wide selection of banjos.
These lines screw together and are not one piece lines though.
Post by: racerrad8 on February 11, 2016, 11:50:45 AM
Quote from: Neoday2 on February 10, 2016, 08:12:41 AM
Hello,
You already have the longer upper line that came with the LSL kit, you would be money ahead if you just replaced the lower two lines and leave the splitter.
Now would also be the time, prior to ordering the new line to upgrade to the blue dot calipers and order the lines for those calipers instead of the stock calipers.
If we can be of assistance getting you the Spiegler lower lines please let us know, we are a Spiegler dealer.
Post by: Pat Conlon on February 11, 2016, 01:33:02 PM
Back in the old days when I converted the forks on my '84 to the '89+ forks and R-1 blue spots, I found that my existing SS lines (with splitter) worked on the blue spots by reversing the sides the lines were located on...
IOW, the stock lower SS lines should work fine with the blue spots..
I'm a fan of Spiegler lines :good2:
Post by: racerrad8 on February 11, 2016, 03:36:26 PM
He does not have S/S lines for the lower section, thus the question.
... I want to replace the rubber lines from the splitter to the calipers...
If he is going to buy new lines, it best get the lower fitting without an angle for the side mount of the blue spots.
Post by: Pat Conlon on February 11, 2016, 03:53:33 PM
I understand...
Here's a 12 year old picture of my "84 with the off the shelf SS lines. These are the same lines I had on my bike when I had the oem anti dive forks and 2 piston calipers. The line angle of the caliper banjos on the R1 blue spots were not too bad.
(http://www.fjrally.com/picgallery/gallery%2F2005_West_Coast_Rally%2FRally19.jpg)
However, yes, straight banjo fittings at the calipers would be better.  :good2:
I like how the Spiegler lines can rotate, or clock, the banjos to whatever position is needed.
Post by: Arnie on February 11, 2016, 07:51:02 PM
Does anyone know if SS lines need to be replaced periodically like rubber lines?
Since the (tygon) inner tubes are covered with the SS braid, there is no visual indication of cracking or damage caused by age, but I'm wondering what the life expectancy or replacement period would be.
Post by: FJmonkey on February 11, 2016, 08:34:52 PM
Quote from: Arnie on February 11, 2016, 07:51:02 PM
I doubt any of us that made the change will be riding long enough to see one fail due to age or proper use (manufacturing/assembly defect, maybe). Rubber is affected by the oxygen in our air, Tygon, an invented word (https://en.wikipedia.org/wiki/Tygon_tubing) not so much... The steel braiding also reduces fatigue from expanding and relaxing. What do I know, I am just a simple Monkey that likes to ride...
Post by: Pat Conlon on February 11, 2016, 09:31:30 PM
That's a good question Arnie.
I recall discussion back in the mid 80's about the issue that the braided ss lines could not get DOT or TUV certification. The lines could handle the pressures just fine but DOT/TUV was concerned about a build up of dirt under the braided skin causing abrasion and possible premature failure of the Tygon inner tube.
Only when the aftermarket folks put a plastic skin over the ss braid did they finally get certified.
Post by: aviationfred on February 11, 2016, 10:07:37 PM
I know that I read somewhere that most braided lines use a Teflon based inner hose, and that they should last the life of your motorcycle.
Galfer has a Lifetime warranty on their brake lines.
Post by: Arnie on February 12, 2016, 06:49:42 PM
Quote from: aviationfred on February 11, 2016, 10:07:37 PM
So, if the line fails they give you a new one? :-)
Consider that our bikes are already past their "lifetime".
So far, the absence of known replacement timeframe is encouraging.
