General Category => Maintenance => Topic started by: Earl Svorks on January 21, 2016, 07:56:14 PM
Title: Chain clearance
Post by: Earl Svorks on January 21, 2016, 07:56:14 PM
A very popular improvement for our FJ models is, of course the fat 17" rear wheel. From my experience, I conclude that ultimately clearance between the chain and the tire is the limiting factor in just how wide a tire you can use, assuming you want front and rear on the same center  line. I have been using a 17"x 6.00  rear hoop for a few years now.   The present tire being a 190/50 Michelin I think the wheel came from an R1. It's a match for the spoke design of the stock front wheel. I use the  530 "O" ring chain. This is a wide chain and I had quite a time making this combination work together. I couldn't find a Yam sprocket on 19 teeth so I cut the center out of a Honda sprocket, then cut the outer part off a Yam sprocket. I assembled them with 5mm of offset and welded them together. With some careful shimming at the back, trimming bolt heads and such I have just a little running clearance between chain and tire.
   My question today is  when looking for more clearance ,could a guy benefit from using a 520 chain and sprockets ? I think they use that size on some powerful racing iron but, I also enclose a picture of a front sprocket that was on my FJ  before the mods
to the wheel. This sprocket failed while on my way to work one morning. I just took off at a light, gave it a little stick and "CRUNCH" I nearly shit myself, thinking I had just broken a shaft or something. I limped to work and when I start to look, about the first thing I see is this sprocket. You can see, it's not worn out, nor was the chain. I wasn't doing (never) smokey burnouts, I didn't pop the clutch. Cheap aftermarket stuff, I guess.
      Simon
Title: Re: Chain clearance
Post by: Pat Conlon on January 21, 2016, 09:43:05 PM
Hello Simon. You continue impress me. I have never seen the work you put into a counter shaft sprocket like you've done. Furthermore, I was not aware that a 19 tooth countershaft sprocket would fit (with a 530 chain) within the confines of the FJ case.
Anyhoo...
I also noticed that the top of the line DID ZVM2 520 and 525 chains have a tensile strength of over 10k, impressive.
Yes, the 160-180+hp sport bikes use them, but we are different (we are special)
The loads on a chain for a 380lb sport bike plus 200 lb rider (say 600-650lbs total) is different than the higher loads on chain for our FJ's that can weigh in at over 900lbs (bike@550; 2 riders@350 plus gear) Weight and torque are killers for chains.
Stay with a 530 chain. FJ's have a higher GVWR than the sport bikes.
Many ways to space your chain out. Here's a quick 4
1) I use the Honda VFR sprocket Marc Rittner describes here (scroll down to #5):  http://www.fjmods.co.uk/MarcRittner.htm (http://www.fjmods.co.uk/MarcRittner.htm)
2) Sprocket Specialists will make you a 1/4" offset sprocket in either 17 or 18 tooth configuration.
3) RPM sells a XJR output shaft that will move your sprocket out (also get the longer clutch push rod)
4) IF needed, do both, the XJR output shaft and the offset countershaft sprocket. You will have to modify the inside of the c/s cover to get clearance.
The get clearance at your back tire you can move the back sprocket out closer to the swing arm if you remove the sprocket studs and install counter sunk SS bolts like Marsh has on his FJ:
(http://fjowners.com/gallery/9/1_18_01_16_8_34_17_8.jpeg)
Again, with the weight and torque of our FJ's, do not roll the dice with a smaller chain. The benefit does not out weigh the risk.
Ever ridden a bike on the freeway (in rush hour) and have the chain break and back tire lock up?  I have, and it was exciting.
I'll get off my soap box now... :pardon:
Post by: Arnie on January 21, 2016, 10:18:48 PM
Both the "broken tooth" and the "centerless" sprocket are 17 tooth.  The mounted sprocket with the paint is an 18 tooth sprocket.  The clearance for an 18 tooth sprocket is barely safe.
Please post a pic with a 19t c/s sprocket mounted.
You could use a ZVM (or equiv) 520 or 525, the strength will be the same, as the rollers and pins are shorter.
But, why do you want a tire that wide?  What benefit do you think you get that is worth so much hassle?
Post by: Earl Svorks on January 22, 2016, 12:25:29 AM
  Good on ya' Arnie, you caught what I missed. I'm not sure how I messed that up. Yes I really did all that and I was sure I had gone from 18 to 19 teeth , obviously it was from 17 to 18. In any case ,I still needed the offset. As to the size of tire, why not? I had the wheel and I enjoy that sort of work. Every bit done in my own little basement shop.The tire is very nice to ride on. I can enter a turn with more confidence, and velocity ,knowing that the traction will be there. I have also found more ground clearance when I'm over on the side of the tire. It doesn't scrape the pegs as easily on the wider tire.
Also Arnie it's not so much the chain that concerns me as the sprocket.
Pat, the flat head bolts on Marsh's bike would work to be able to bring the sprocket closer to the s/a. I should have realized that myself. Do we know how Marsh was able to move the front sprocket out ? I think that would be required,
   Simon
Post by: oldktmdude on January 22, 2016, 12:26:05 AM
Quote from: Arnie on January 21, 2016, 10:18:48 PM
The only benefit that I can see in the 190 is it's a lot easier to seat the bead on a 6" rim. I fitted a 180 to a 6" rim for a mate of mine and had a
hard time trying to get the tyre beads to seat. You need a lot of air volume and a tie-down strap to make it easier. No other advantage that I can see.
Pete.
Post by: Bones on January 22, 2016, 01:29:53 AM
Quote from: Earl Svorks on January 21, 2016, 07:56:14 PM
My little 250 Suzuki 2stroke puts out a mighty 30hp and weighs 128kg and has a 520 chain on it (standard fitment.) Probably overkill, but if a light 250 has a 520 chain on it, I'd be wary of putting one on a bike with twice the weight and 100 hp more.
I know modern chains are strong, and if you rode like a grandma it probably wouldn't be a problem, but if the manufactures specify a 530, I wouldn't go smaller.
Post by: Pat Conlon on January 22, 2016, 10:20:24 AM
That's only 1/2 of the equation, what about the thinner sprockets?
Post by: Earl Svorks on January 22, 2016, 02:21:37 PM
Pete.
[/quote]   Pete,
    Like the switch from bias ply to radial tires, there is no advantage that you can see.The advantage is in what you feel when you ride, when you're using the tire.
  Simon
Post by: movenon on January 22, 2016, 07:06:27 PM
For a smile  :good2:
(http://fjowners.com/gallery/9/1651_22_01_16_7_04_45.jpeg)
Post by: Earl Svorks on January 22, 2016, 07:56:30 PM
  George, the FJR  appears to have a rear tire from the Dark Side.  Tell me it ain't so !
      Simon
   Nice lookin' ride BTW, is that one yours ? The FJ looks the business too.
Post by: Pat Conlon on January 22, 2016, 09:24:28 PM
The FJ is George's and she is beautiful....he has put a lot of love into that bike and it shows. :good2:
He also knows better than to put a fucking car tire on his bike.... I can not believe people do that.
Post by: TexasDave on January 22, 2016, 10:39:16 PM
I have seen more than a few FJR's sporting car tires. A few of the IronButt FJR riders run them and never have to worry about rear tire wear for the event. In the rules however it stipulates they have to have tire pressure monitors if they run one but why I don't know.  Dave
Post by: movenon on January 23, 2016, 12:13:28 AM
Thanks Pat and Earl but you guys set the standards I am just trying to keep up.
The owner of the FJR in the picture rode it up to Alaska and back with no tire problems. I followed him for a while in some twistys while looking a little odd it seemed to work pretty well. I am under the impression that a number of FJR owners do this for long rides. I forgot exactly but he indicated 15 or 20,000 miles on the tires?  He also said Cycle Gear wouldn't mount them because of liability but ironically the Yamaha shop had no problem mounting them.
I would like to ride with him next spring and take some video. Sorry about high jacking your thread Earl just thought you would get a kick out of the tire :).
Post by: Earl Svorks on January 23, 2016, 04:30:34 PM
  Pat,
Locking up a wheel om the highway ? You are lucky to have walked away, assuming you did.
  This brings to mind an experience  on the highway to Fargo ND where we would go for the indoor short track held at a fairground facility there. This was in 1977 or thereabouts.
  I had just installed 2 new TT100 tires on the Ducati 860GT I rode at the time. I was in the habit of using sunlight soap on the bead to ease fitting tires and minimize the risk of pinching the tube with the tire iron. Standard procedure at the shop where I worked.
  Here we are, 2 up me and the girl, doing about 60 mph southbound on I 75 we're on the US
side of the border, coming from Winnipeg. All is well,,, until I felt something  odd, and the rear tire just went flat. Not a blowout, it seemed to take about 3 seconds . I pulled the clutch in and the rear end tried to pass me. The bike went what seemed like right to the steering lock , then left all the way to the lock. The cycle repeated 3 or 4 times , each time with less amplitude, a slow motion tankslapper.  We came to a stop on the shoulder. The bike had remained upright and calm during the whole event.
  We were traveling with a group of racers and support vans that held the 3 or 4 racing bikes and spares . I removed the wheel right there , a spare tube was found, an inch different diameter, but close enough. What surprised me most was finding the root cause of the whole event. The new tire had apparently turned on the rim, and torn the valve stem out of the tube. The Duc had no rim locks and the soap residue had allowed the tire to slip. Lesson learned.
   I credited  the Ducati for it's inherent stability , allowing us to walk away from the event. This event was not the only time the Duc proved this to me , but that will keep for another day.
  Simon
Post by: Pat Conlon on January 23, 2016, 04:50:35 PM
My heart rate spiked reading that Simon, I can relate, I was there.  Tube tires? I remember those.
So...it sounds like we know all about Guardian Angels, huh? I scoffed at my parents, silly old superstition.
I want to be like Noel. I think a motorcycle tire pressure monitor is a very very good idea. It's on my list.
Post by: Arnie on January 23, 2016, 05:52:45 PM
Simon,
That's the first time I've read an account of a "slow-motion tank slapper" which sounds very similar to what I experienced.
I was on my way home to Detroit from Michigan State on I-96 where I was a Sophomore in 1969.  Crusing along in a straight line at about 75mph on my Bultaco Metralla 250 (2 stroke single) when the rear end stepped out.  I was able to catch it and bring it back only to have it go the other way.  I was afraid to either brake or try to accelerate and I just held on with the clutch pulled in thinking it might have been an engine siezure . This tail whip continued all the way down to about 10mph getting most violent at about 30 (?).  After I stopped still upright and had the bike off the roadway, I discovered that my rear tire was flat.
I put the bike in a semi-hidden position (so it wouldn't be stolen or collected by the police), got my gear off the bike and stuck out my thumb.  A guy in a station wagon stopped for me and after I was in the car with my stuff in the back seat, he asked where my bike was since I had a helmet and leather jacket with me.  I told him my story and he asked if the bike would fit in the back of his car.  I thought so, so he got off at the next exit and went back about 10 miles where we loaded the 200 lb bike in the back of his station wagon.  He took me right to my parents house.  Turns out he was a minister and actually practiced doing as he would want done. :-)
The bike had a flat and after inspecting closely, I saw a glimmer of metal in the tread.  Grabbed it with a pair of pliers and pulled out about 3" of sabre saw blade. :-(  Patched the tube and kept riding.
With a tubeless tire, I'd probably have made it home without incident, none the wiser.
After this, it was the first time I had any confidence in my motorcycling skills.
Post by: Earl Svorks on January 23, 2016, 08:01:11 PM
  Arnie,
Well now we know there are at least  three among  us who survived what might have been a terminal event. Pat evokes the Guardian Angels. You'll get no argument from me there Pat.
  Arnie, you were fortunate to have been the recipient of a Random act of kindness, after your close call.
I've been there too. I think it's important to pay that forward when you can. I try to do so, though it's hard to be sure you're not being played. I guess I have been played a time or two, but they haven't made a cynic out of me yet.
  Simon
Post by: Pat Conlon on January 23, 2016, 08:55:23 PM
Yep, pay it forward...
Post by: ribbert on January 23, 2016, 09:38:23 PM
Quote from: Pat Conlon on January 23, 2016, 04:50:35 PM
......I think a motorcycle tire pressure monitor is a very very good idea. It's on my list.
A couple of years back I had the first puncture I could ever recall having. Whilst I was in the company of a couple of other experienced motorcyclists, they too had been spared punctures for many decades of riding, which made us all novices in the use of repair plugs.
Anyway, job done (on second attempt), riding home I approached a red light at an intersection and made my own 3rd turn lane on the outside of the two marked ones. No big deal, I do this all the time, you just have to make sure you get the jump on the cars and turn in front of them, joining their turning lanes before you run out of road.
Being conscious of the repaired tyre and failed first attempt, I was monitoring my tyre pressures more than usual. I glanced at it as I came to rest, yep, no worries. While I am waiting for the light to change, my tyre pressure monitor display starts flashing along the with the red warning light and see my tyre pressure plummet to nothing while I am sitting there, just as the light turned green.
The simultaneous launch and turn the manoeuvre required would have seen me go maybe 10' and end up sitting on my arse in the middle of the road with significant cosmetic damage to my bike (assuming no one drove over it)
More recently the monitor (and compressor) saved me from spending a night in the wilderness (if I didn't fall off first with a rapidly deflating tyre) with temps dropping to zero, let alone the logistics of retrieving the bike from such a remote location the next day and then not being able to get it repaired until after the weekend etc. It would have resulted in completely missing the Manshed weekend in Nowra I was en route to.
The monitor also shows tyre temps continually, it was interesting to note with my leaking tyre recently, the correlation between falling pressure and increased temp. It got very hot very quickly. Once under  20 psi, a faint smell of rubber was even apparent when kneeling next to the tyre while re inflating it.
Mostly though, it is peace of mind while riding and to a lesser extent, the ease of pre ride checks. It also has a low voltage warning light which for me, is enough to not need a volt meter.
I have had this unit for about 5 years / 100,000kms and it has proven to be totally accurate and reliable. I keep forgetting to change the batteries when I change tyres and they are still the originals.
On trips any longer than a day ride, I carry a spare ignition box, fuel pump, compressor, one coil (with leads), tools, test light etc. You can limp along on a couple of cylinders, you rig up something for a broken throttle cable, you can ride without a clutch, you can ride without brakes, you can hot wire your ignition, you can jump start the engine, you can get by without lights, you can even patch a hole in a side cover or crankcase, you can ride it bent and broken after an off (assuming you're not in the same shape) and so on......
BUT, you ain't goin' nowhere with a flat tyre!
I do a lot of trips, have penchant for out of the way places and roads free of other traffic. Anything the hedges the bet for getting to my destination is a good thing.
Aaah Pat, the fun I could have had with that ............. :biggrin:
Post by: Earl Svorks on January 24, 2016, 12:10:19 PM
Quote from: movenon on January 23, 2016, 12:13:28 AM
QuoteI would like to ride with him next spring and take some video. Sorry about high jacking your thread Earl just thought you would get a kick out of the tire :).
George,,
Hijacked ? Not at all, I am happy to see feed back/ input from you anytime. Sensible, intelligent , helpful,, and you've got a fine lookin' FJ !
  Simon
[/quote]
Post by: 1tinindian on January 24, 2016, 05:11:31 PM
Quote from: movenon on January 22, 2016, 07:06:27 PM
For a smile  :good2:
This, at least, eliminates the worry of squaring off a soft compound tire while slabbing the miles away!
