I want to replace the fuel filter. Is there a better aftermarket filter available?
Quote from: Yamahammer1200 on October 30, 2015, 10:24:48 PM
Not that I have found, the hose size is the biggest problem as it is 9mm. Most aftermarket filters are either 6, 8 or 10mm. The problem with one that is too small for the hose is the clamp sometimes cant compress the hose and they leak. If you get a 10mm the hose splits open.
That is why I only offer the
Yamaha 89+ FJ Undertank Fuel Filter - O.E. (http://rpmracingca.com/proddetail.asp?prod=M%2FC%3AFF-O.E.) for the FJ as it is the only one I have found that fits properly and does not create a fire hazard.
Ok, I will have to order a filter from you soon. I saw a few rust pinholes when I shined a light down in the crevices of the tank. I have been using Heet to remove any residual water.
