General Category => Maintenance => Topic started by: WeaponWorth on September 11, 2015, 01:21:56 AM
Title: Taking off my valve cover
Post by: WeaponWorth on September 11, 2015, 01:21:56 AM
Hey guys I just removed the eight screws on top of my value cover and it won't come off I taped it with a rubber mallet and it still Will not budge so do I have to slide a razor in between the gasket to get it up
Title: Re: Taking off my valve cover
Post by: Harvy on September 11, 2015, 01:39:23 AM
Sounds like someone has used silicon on it.
If you have to use a blade to remove it, make sure you have a new gasket, and don't use any silicon when you put the cover back on....... a smear of grease will hold it in place.
Post by: WeaponWorth on September 11, 2015, 01:51:27 AM
Quote from: Harvy on September 11, 2015, 01:39:23 AM
spot on I do know what this guy did to this bike but I go my work cut out. He even used it to shot cut getting a gasket for the crank case cover has oil dripping every where. Also it seems like there is exhaust leaking from the cover is well I think that's why he used it to seal the screws on in the picture below
Post by: Harvy on September 11, 2015, 03:04:37 AM
Wow, that has had a hard life hasn't it.
You will also need 8 new grommets for the bolts holding it down. The grommets are gaskets for those bolts. The bolts themselves are shouldered and must not be over tightened.... just snug them down and let the gaskets (bolts and circumference) do the job of keeping the oil in.
Post by: WeaponWorth on September 11, 2015, 05:16:03 AM
Quote from: Harvy on September 11, 2015, 03:04:37 AM
nice that part I had no idea about, the grommets that i. Thanks again Harvy
Post by: WeaponWorth on September 11, 2015, 05:18:51 AM
Yeah it's had a hard life up till now but now that it's in my hands ill nurse it back to health step by step
Post by: fj johnnie on September 11, 2015, 06:21:52 AM
 Grease works perfect as Harvey says. Remember when you first run it after installation the grease will run a little and stink a bit. Let it run for a bit before checking for leaks.
Post by: WeaponWorth on September 13, 2015, 06:30:29 AM
Ok cool thanks guys
