General Category => Maintenance => Topic started by: biggo on August 14, 2015, 08:08:30 PM
Title: How much play in Rear suspension is OK?
Post by: biggo on August 14, 2015, 08:08:30 PM
Hi All.
Have stripped cleaned and re-greased all my rear suspension linkages and bearing. Very slight tarnishing on bushes that run inside roller bearings but no visible wear.
We everything reassembled and rear wheel off the ground if I put a lever between bottom of rear tyre and the floor I can lift the wheel about 2-3 mm before any resistance from the shock. i.e There is a small amount of play so really after some thoughts on what might be considered acceptable.
Thanks  Phil
Title: Re: How much play in Rear suspension is OK?
Post by: mr blackstock on August 15, 2015, 09:09:42 PM
G day,
I reckon the amount of play you have is fine. There are exact figures in the manual but if you dont have one to check
Don't stress too much until your clearances increase
Cheers, gareth
Post by: Mark Olson on August 15, 2015, 09:20:29 PM
As long as the side to side play is minimal ,you are ok.
Post by: biggo on August 18, 2015, 02:59:59 AM
Thanks for the feedback I think I will just monitor it maybe get new bearings next time I strip and clean them
Cheers  Phil
Post by: CutterBill on August 18, 2015, 07:50:02 AM
If you have play in the suspension, that means something is worn out or loose.  If it were me, I would find it and fix it.
Post by: mr blackstock on August 18, 2015, 06:19:37 PM
G'day,
I am pretty sure that when I looked in the manual about suspension awhile ago, a small amount of play was allowable, considering the leverage in relation to the length of the swingarm I would be pretty surprised if there was no play.
Biggo, In relation to buying suspension parts, go through part shark out of the U.S, much cheaper than the local suppliers.  When I revamped my suspension the cost difference was huge!
cheers, Gareth
(http://fjowners.com/gallery/5/1121_20_06_13_10_01_26.jpeg)
