General Category => Maintenance => Topic started by: anson45 on July 18, 2015, 10:53:04 AM
Title: motor mount torque values 1989 FJ1200
Post by: anson45 on July 18, 2015, 10:53:04 AM
     I have a Haynes Manual and a Clymer. The listed motor mount values are different. Does anyone have a Yamaha Shop Manual?
Haynes, page 2-4, lists for 1984-1990: upper damper bolts = 40 ft-lbs, flange bolts = 65 ft-lbs, rear down tube-to-frame bolts = 40 ft-lbs. Clymer, page 159, lists for 1984-1990: upper front through bolt and nut= 40 ft-lbs, upper rear through bolt and nut = 40 ft-lbs, Lower rear through bolt and nut = 65 ft-lbs, and Sub-frame upper and lower bolt and nut = 20 ft-lbs. I and the po's used the Haynes values.
So my question is, what are the Yamaha values?
Anson
Title: Re: motor mount torque values 1989 FJ1200
Post by: ct7088 on July 18, 2015, 12:54:29 PM
Front and Rear Upper and Rear Lower Engine Mount 40 ft/lbs (M10 X 1.25)
Rear Lower Engine Mount 65 ft/lbs (M12 X 1.25)
Front Frame to Rear Frame 40 ft/lbs (M10 X 1.25)
I hope that the picture of the page shows.
Chris
Post by: ct7088 on July 18, 2015, 12:55:29 PM
No Picture.
Reading instructions
Post by: ct7088 on July 18, 2015, 01:09:24 PM
(http://fjowners.com/gallery/9/4224_18_07_15_12_07_57.jpeg)
Post by: anson45 on July 18, 2015, 01:47:52 PM
Wow!
Thank you very much,
Anson
Post by: Burns on July 18, 2015, 04:15:17 PM
thank you both for making this great thread.
