Need to know the size of the nut for the front sprocket for a '92 FJ. Reassembling suspension/swingarm and new F&R sprockets and chain. Realized that's a big honkin' nut that I don't have a wrench or socket for. I took a tape measure to it (don't have a guage/mic) and looks like 35mm.
Can anyone confirm this? Kinda' stuck until I find out.
Thx
I have an old 1 7/16 inch socket that I use. TQ is 61 ft lbs. Left off, right on :). I ground down the face a little to get a better bite on the thin nut. The marking on my socket is almost gone but I believe it to be an 1 7/16 inch socket (it is a road kill socket found in the road years ago). That would be about 36mm.
(http://fjowners.com/gallery/6/1651_01_10_13_7_59_20.jpeg)
I used a 2X4 across the swing arm through the rear wheel to lock it down for removal. Hopefully your chain is still on :).
According to the online conversion site 1 7/16 in. = 1.4375 in. = 36.5 mm Round down to 1.4 in = 35.5 mm
So 36 mm ... 35 mm? I'm getting confoozed.
Quote from: PaulG on April 29, 2015, 04:35:17 PM
The Yamaha spec is 36mm. :) The 1 7/16 works fine. Either one will work. Big nut big tolerance. :).
Great! Thanks for the prompt reply. Off to spend some more dough. :yahoo:
