General Category => Maintenance => Topic started by: twangin4u on April 24, 2015, 10:00:05 AM
Title: hey.. what's that?
Post by: twangin4u on April 24, 2015, 10:00:05 AM
Took my master cylinder off a few weeks ago at a buddies house. As I loosened the plastic containing the turn switch and horn next to the grip on the left bar this little piece of plastic fell out. At least I think it fell out of there. There were distractions  :sarcastic:
Anyway, I've has this little piece of plastic floating around in my garage and it's sure to get lost at some point. I couldn't figure out where it went so I just put everything back together and everything works perfectly so....
Does anyone know where it goes?
'84 fj1100
Title: Re: hey.. what's that?
Post by: red on April 24, 2015, 01:33:48 PM
Quote from: twangin4u on April 24, 2015, 10:00:05 AMTook my master cylinder off a few weeks ago at a buddies house. As I loosened the plastic containing the turn switch and horn next to the grip on the left bar this little piece of plastic fell out. At least I think it fell out of there. There were distractions  Does anyone know where it goes?  '84 fj1100
Twangin,
If you were on the choke side, then I believe that piece keeps the choke cable in the groove,
secured by a Phillips screw in that hole. It might work that way, but I'd want that piece back in there.
Post by: copper on April 24, 2015, 01:50:20 PM
Red nailed it there is a small slot that; that piece will slide into and there is a small phillips screw holding it on. It does hold the cable in the groove, possibly to keep the cable from coming out while twisting the choke.
Post by: twangin4u on April 24, 2015, 05:48:14 PM
Right on. Thank you.
