General Category => Maintenance => Topic started by: turbocamino on January 08, 2010, 10:25:05 PM
Title: new vibrations at 3000 RPM
Post by: turbocamino on January 08, 2010, 10:25:05 PM
Gentlemen, recently started having a couple issues that may be related.....when i drop it in gear the "clunk" seems to have gotten severe, am relatively sure the clutch is ok, as its never a fight to catch neutral parked or otherwise and engagement point hasnt changed......also, a vibrations has crept in around 3000rpm. So..i'm thinking a motor mount issue?   I see two, forward of motor, that appear to be rubber and hopefully arent difficult to service. Does this sound like the right direction?   thanks
Title: Re: new vibrations at 3000 RPM
Post by: racerman_27410 on January 08, 2010, 11:40:39 PM
check all the motor mounts.... check carb sync.... check output shaft for excessive play ...... check wheel bearings...... what does your chain look like? any tight links and or rust anywhere?
has the valve lash been checked/adjusted recently?
lots of things that can be checked for sure.
Post by: Arnie on January 09, 2010, 07:25:03 AM
And, in addition to all the checks Racerman gave you, check the lower frame rail bolts are all in place and tight.  These can loosen and have been known to shear.  Depending on year, you may have to remove the footplates to properly check.
Post by: turbocamino on January 09, 2010, 09:08:43 AM
  ok,thanks..this gives me some direction to go....bike in questions is an 89 with 14K and in fantastic condition..i will go-over all m/mount bolts etc...chain is a bit old as well. thanks again.
Post by: andyb on January 10, 2010, 10:59:30 PM
The only thing to add is to take a peek at the cush drive.  Excessive beating on it will bork it up.
