General Category => Introductions => Topic started by: ct7088 on February 25, 2015, 09:41:55 PM
Title: Old FJ Owner
Post by: ct7088 on February 25, 2015, 09:41:55 PM
I bought my 85 in January 1985 but I have let it set for twenty years. The list of repairs, OH and replacements was extensive and as usual my initial estimate was tripled by the time it was road worthy. I have read much good advise on this forum which i have and will continue to use. Special thanks to Randy at RPM for jetting and sprocket advice(good parts, quick shipping. On a different note does anyone know the length of the brake line from master cylinder to the divider joint in the Spiegler  S-YA0132 (1985 FJ with anti-dive) brake line kit? I have installed the RPM riser kit and while the original line works it needs to be longer.     Red and White  :good2:
Title: Re: Old FJ Owner
Post by: aviationfred on February 25, 2015, 10:36:03 PM
Welcome to the forum  :hi:
It is great that you found us. As an original owner, you already know the great attributes of the FJ. It is always a joy to read about an owner bringing their FJ back to life.
I often ride in Oklahoma. Usually down to Stillwater and Warwick once or twice a year. Rides to Blackwell and through Ponca City are pretty regular.
Post by: movenon on February 25, 2015, 10:47:40 PM
Welcome to the group ! I was born not to far from OKC (Thomas) and still have relatives in the area. Hoping to ride down there after the Central FJ rally in June.
Post by: Pat Conlon on February 25, 2015, 11:15:26 PM
Hello Chris, welcome. I'm glad you're getting your bike back into action.
Re: The Spiegler kit vs. RPM's bar risers. You will be "ok" with the standard length the kit offers...just ok...the advantage on dealing with Spiegler is they can add line length to any kit they offer...that's what I would do.
Give them a call and ask them to add 1" to the line running from the m/c to the splitter. They will look up on their tables what line length they normally use, and add to that length.
Sorry but I don't have that length for you, I run a double line from my m/c to the calipers. 2 less less banjo fittings that way. Years ago I had that T fitting crack so I never went back to it...
Post by: moparman70 on February 25, 2015, 11:53:27 PM
Welcome Chris -- I can vouch for what Pat says -- I had a set of front brake lines that were from an 86  and I put them on my 90 model with risers and the length was no issue.  I also bypassed the T-joint -- If you are going to the trouble of replacing you may want to do the same.  I could give the length of the set I have and you just have to get a double banjo bolt for the master.    Less places for air to hide and easier to bleed too without all the extra connections.
PS --- we are all od FJ owners.... aren't we?
sc2
Post by: Mark Olson on February 26, 2015, 01:10:00 AM
Hi Chris,
I have pats old ss brake lines from his 84 on my 86 . I rececenty installed the rpm risers and they fit with the master cylinder end of brake line clocked straight down. I would suggest adding 2" to the line length so you have some room for a different master cylinder in the future. I am using an fjr1300 brake master.
Post by: FJ_Hooligan on February 26, 2015, 01:39:01 PM
Another reason to add some length is to provide slack so you can remove the master cylinder from the fork tube without removing the brake line.  Makes changing fork oil easier.
Post by: ct7088 on February 26, 2015, 08:48:26 PM
Thanks for the advice. I sent an email to Spiegler but a phone call may be a better choice. I was thinking about one inch extra but now two inches extra sounds better. The master cylinder is in good condition and I hope it will last a while longer. My wish list exceeds available funds. Has anyone used the replacement sight glass? http://newrivercyclesalvage.com/sight-glass.html (http://newrivercyclesalvage.com/sight-glass.html) My clutch master sight glass oozes especially when its cold. I'm looking forward to opportunities to ride and meet other FJers even Hooligans. :smile:
Post by: FJ_Hooligan on February 26, 2015, 09:09:01 PM
Quote from: ct7088 on February 26, 2015, 08:48:26 PM
Arkansas in June!  Get it ready by then.
You might want to check out VENHILL for brakelines.  I got less than stellar customer service when I tried asking Spiegler questions.
Post by: Country Joe on February 26, 2015, 09:44:04 PM
I second the recommendation for Venhill brake lines. Great quality and great customer service. :good:
Post by: ribbert on February 27, 2015, 03:32:16 AM
Quote from: Country Joe on February 26, 2015, 09:44:04 PM
Good sercice doesn't really come to the fore until you have a problem. How a company then deals with it is what sets them apart from the rest.
I had an issue with hose length and the way they handled it was outstanding.
IMO brake hoses are brake hoses and as long as they come from a known company and have rotatable banjos there is bugger all difference between them but I do think some companies capitalise on brand snobbery for what is an incredible simple item.
Call me cynical but I wouldn't be surprised if many of these companies bought their components from the same suppliers.
I bought Venhill for a range of reasons and the price was attractive. Their great service only became apparent after I had bought their product, they already had my money.
I also didn't waste a lot of brain power arriving at my decision, they are after all just a brake line!
Venhill gets a thumbs up from me and I have plenty of experience to measure them against.
Post by: FJ1100mjk on February 27, 2015, 04:02:51 AM
I did for a front brake's master cylinder. Going on 3+ years of use, and works fine. I embedded it in its bore with a clear RTV sealant. I am running silicone brake fluid in the brake systems, so the adhesive is compatible with it.
If you are still going to run non-silicone fluid (DOT 3, DOT 4, ...) in your clutch system, check with New River Cycle Salvage on what glue/adhesive to bond the sight glass with.
Post by: mark1969 on February 27, 2015, 04:17:06 AM
I've got Venhill brake lines, and they look the same quality as any other brands I've used in the past. I've not had a chance to test them yet having fitted recently, but they will be great I'm sure.  :good2:
Post by: ct7088 on February 27, 2015, 08:23:08 PM
Venhill is checking the price for brake 85 FJ brake lines. Sight glass ordered, RTV is the recommended sealant for DOT 3, 4 and 5.1. Eighteen degrees with snow here, its warmer in Idaho!
