General Category => Modifications => Topic started by: scotiafj on February 19, 2015, 01:16:55 PM
Title: rear sprocket size
Post by: scotiafj on February 19, 2015, 01:16:55 PM
Hi guys I'll be doing the suzuki 17'' 4.5 rear wheel  conversion on my 93 3xw soon and I'm wondering what rear size sprocket to use  I'll be using the standard 17t front I want to try and keep the same gearing as standard and not revvy with using a larger rear sprocket ...what size rears do you guys run ? cheers Scott  :good:
Title: Re: rear sprocket size
Post by: Mark Olson on February 19, 2015, 01:39:49 PM
For your year 93 .. 17/40 ... some have gone to a 18/38 for mileage reasons.
I run 17/41 for most the time and switch to 18/41 for cross country runs.
With your wheel swap being done it will give you a lower profile tire and depending on which tire you use , may be equal to 1-2 teeth on the rear sprocket.
Before you did the swap , what was your 5th gear rpm at cruise speed .  you can use that to determine what sprocket will get you back to normal.
My advice is to run what you had on the stock wheel and see how it feels to you.
Post by: ZOA NOM on February 19, 2015, 01:43:50 PM
The GSXR wheel I bought had a 43t sprocket, which I have found to be a little high on the revs at cruising speed, especially with the 17t. I then bought the 18t front sprocket from RPM, which dropped the revs to a more acceptable level, albeit still a little high for my taste, so I ordered a 40t suzuki rear sprocket to go with the 18t up front, which should be a good combo.
Post by: scotiafj on February 19, 2015, 01:49:11 PM
I think it was 4000rpm @ 70mph so wanting to try and keep to that kinda rpm standard gearing on the fj jus now is 17/39 :)
Post by: Mark Olson on February 19, 2015, 02:10:24 PM
Quote from: scotiafj on February 19, 2015, 01:49:11 PM
There is a gearing chart in the files section that can help you..
The 17/39 should be ok  . run it and see how it does.
It is easy to change a rear sprocket later if you want, Or maybe change the c/s to an 18 .
Post by: Bones on February 19, 2015, 02:13:08 PM
The gsxr wheel I bought has a 48 tooth sprocket on it, fantasic if you want to ride around on the back wheel, but I'm getting a bit old for that, so I'll probably get a 38/40 to keep the gearing much the same as it is.
Post by: FJmonkey on February 19, 2015, 03:29:58 PM
Use the www.gearingcommander.com (http://www.gearingcommander.com)
Put in what you had assuming that is what you like), then play with the gearing to get it where you want it.
Post by: ZOA NOM on February 19, 2015, 04:13:44 PM
Great tool, Monkey. I think I'm gonna like 72mph at 4250rpm with the 18/40 combo.
Post by: TRoy on February 19, 2015, 06:09:12 PM
unless something has changed since i checked a few years ago.... the smallest suzuki sprocket you can readily buy is 42, anything smaller was 'custom /special order' ...if you look and find let us know :)
Post by: Pat Conlon on February 19, 2015, 06:46:23 PM
Sprocket specialists will make it for you.
The question is, will a 40 tooth fit on GSXR hub and still get the 530 chain fully seated on the sprocket? (without touching the hub)
I have the YZF1000 Thunder Ace wheels on my bikes and I can tell you that the smallest sprocket I can run on the hub is a 39 tooth..
I tried a 38 tooth and the chain's side plates (right side) dug into the soft aluminum hub....so, I have the scars to prove it.
Post by: movenon on February 19, 2015, 07:12:32 PM
The only thing I can add is what Pat alluded to. Make sure your rear sprocket is for a 530 pitch chain. From memory I ordered a GSXR 750 sprocket.
JT sprocket has a good web site.  Check out there catalog. And they are available just about everywhere even e bay.  I ran an 18/38 then later converted to a 17/38 but that all depends on the type of riding you do.
http://www.jtsprockets.com/cat alogue (http://www.jtsprockets.com/cat%20alogue)
Post by: FJmonkey on February 19, 2015, 07:40:55 PM
I have a '92 GSXR 750 rear wheel and got a sprocket for it from Johnson Woods here in CA with 38T. It was off the shelf but not their shelf. So they are out there.
Post by: FJscott on February 19, 2015, 07:43:23 PM
Echo on the pitch. I had a hard time getting a 530 sprocket for my Gixxer wheel. I had to have one custom cut from Sprocket Specialtys.
Scott
Post by: ZOA NOM on February 20, 2015, 08:53:28 AM
Found this on Ebay. Looks right to me. Am I missing something?
Post by: chocker on February 20, 2015, 03:54:59 PM
I have a 93 and I'm running 18/40. It has a nice power band.
Mark
Post by: TexasDave on February 20, 2015, 04:09:31 PM
Running 18/40 works for me too.  Dave
Post by: andyoutandabout on February 21, 2015, 12:02:19 AM
Fjers often comment on my big one. Madam
I've run an 18 up front and 46 rear for ages.
This results in about 60 mph at 4000 rpm which feels fine to me with regards to all round vibes.
I use the Fj for everything since I have no car. Commuting to work is nice as I can easily nip through traffic with a blip of gas and this eagerness translates well to weekend canyon adventures. As for long distance; one year I rode Route 66 and all worked well. 5000 rpm gets about 75, which buzzed me along quite happily from L.A. To Chicago.
Andy
Post by: Mark Olson on February 21, 2015, 02:16:08 PM
Quote from: andyoutandabout on February 21, 2015, 12:02:19 AM
Andy
Oh I see , that explains a lot Andy..  :wacko2:
