General Category => Maintenance => Topic started by: junkyardroad on December 22, 2009, 10:00:55 PM
Title: Where does this plug go?
Post by: junkyardroad on December 22, 2009, 10:00:55 PM
Can anybody tell me where this white plug goes to? It is right next to the fuel pump.
(http://i255.photobucket.com/albums/hh156/junkyardroad/PC220014.jpg)
Title: Re: Where does this plug go?
Post by: Arnie on December 22, 2009, 10:43:21 PM
My guess is that it goes to an electric vest OR is possibly used for a battery charger.
Have you tried to measure if it has 12V from the 2 pins with the ignition both ON & OFF ?
Post by: Marsh White on December 22, 2009, 11:15:20 PM
Quote from: junkyardroad on December 22, 2009, 10:00:55 PM
Nowhere.  Honestly.  It came that way stock.  We had this discussion many years ago on the Yahoo forum - someone did figure out why it was there....but I don't remember.  Bottom line - it's just there - you are NOT missing anything.
Post by: andyoutandabout on December 22, 2009, 11:46:13 PM
Most odd. Never get those kinda things on 86s.
Post by: fj1289 on December 23, 2009, 12:29:54 AM
I think you're supposed to put a jumper wire there when you're chaning the muffler bearing... :biggrin:
Post by: tqmx1 on December 23, 2009, 12:38:39 AM
Cal. smog. Itwascheeper to put it in all the harnesses than to make spechial ones.
Post by: andyoutandabout on December 23, 2009, 12:49:02 AM
Nice photo. It solved a question I had about a mystery bracket. I see the lug holds your suspension thingy. My Fox reservoir sits elsewhere.
Post by: rossco on December 23, 2009, 01:51:09 AM
Heck that's  clean/new engine.
Would the electrical schematics show it up?????????  $0.02
Post by: FJ Flyer on December 23, 2009, 12:49:58 PM
The 86/87s have a smaller plug, I think its brown, in the same location, for CA smog stuff.  Since the hot side is switched, I used it to power the relay for my hot grips.
Post by: jvb_ca on December 23, 2009, 04:30:23 PM
Is that the same as a green connector on an 86? Mine is now used to power my gps. Thankyou Yamaha for providing that for me... :good2:
Cheers....Jake
Post by: spsmith_fj1200 on December 23, 2009, 08:00:26 PM
Quote from: Marsh White on December 22, 2009, 11:15:20 PM
I asked this question back in May of 2007 on the Yahoo Forum.
Post by: junkyardroad on December 23, 2009, 08:23:20 PM
I didn't waste a lot of time on it, thankfully.  Too many other jobs that are more fun.  Finding it on the schematic wasn't informative but it was there. May as well use it for gps, grips or a heated sock for my wiener.
Post by: FJ Flyer on December 23, 2009, 09:38:51 PM
Quote from: jvb_ca on December 23, 2009, 04:30:23 PM
Cheers....Jake
Yeah, now that I think about it, it is green, not brown.
Post by: TRoy on December 26, 2009, 06:04:29 PM
Quote from: FJ Flyer on December 23, 2009, 09:38:51 PM
green plug... brown wire is switched B+, black wire is ground
