General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: Sabre093 on September 21, 2014, 11:01:14 PM
Title: Flappendectamy
Post by: Sabre093 on September 21, 2014, 11:01:14 PM
I've got this problem....saw the pdf file on dissembly,not sure what I got to do to fix problem..
Title: Re: Flappendectamy
Post by: Steve_in_Florida on September 22, 2014, 07:36:17 AM
Quote from: Sabre093 on September 21, 2014, 11:01:14 PM
Your question is rather ambiguous.
Is the problem that you saw the PDF, or ???
How is the issue manifesting itself. Does your FJ "sing" after a ride? If so, then you have to remove the little rubber flappers that are restricting the airway.
If not, then please restate your problem with a bit more detail.
Post by: Sabre093 on September 22, 2014, 09:33:08 AM
It's dying like running out of gas...I am sure I need to do this and yes it sings too...I saw the pdf file on this but not sure what needs to be removed.
Post by: Pat Conlon on September 22, 2014, 11:30:19 AM
My money is on....either 1) Vacuum Petcock failing to stay open..or 2) a fuel line pinch from incorrect fuel line routing....
Do you have the rubber flappers on your '86? (I didn't on my '84)
The rubber flappers are on the '89+ fuel pump bikes. (I had them on my '92)
Regardless, if you have them, cut a pie shape notch out of the sealing surfaces or just remove them entirely.
Post by: FJmonkey on September 22, 2014, 11:30:51 PM
I am with Pat, my petcock failed and gave me all sorts of problems. I did the Flapectomy and unknowingly messed that up as well. After I gave my petcock the suck test...  :shok:, yes I said it.... I knew the petcock had a vacuum leak. After I replaced it, I still had issues...  :ireful: :ireful: :ireful: Then at a West Coast Rally Randy got me sorted out and found my error. If you chose to remove the flaps, remove the entire white plastic piece that holds them. The V cuts will not work if you install the white plastic piece upside down...  :mad:
The Suck Test...
http://www.fjowners.com/index.php?topic=9787.msg95549#msg95549 (http://www.fjowners.com/index.php?topic=9787.msg95549#msg95549)
