General Category => Modifications => Topic started by: Easterntide on September 16, 2014, 06:48:18 AM
Title: Oxford Heaterz Wiring Question
Post by: Easterntide on September 16, 2014, 06:48:18 AM
Just ordered 2 sets of Oxford Heaterz Premium Sport Heated Grips, one for my fj and one for her cbr125 as fall is settling into atlantic canada. Has anyone else installed same? Do you need to connect these to the battery direct or is splicing required? and if splicing...any specifics would be very helpful.
Grips will arrive tomorrow.
thanks all,
Don
Title: Re: Oxford Heaterz Wiring Question
Post by: Bob on September 16, 2014, 07:08:06 AM
I wired my heated grips (from http://www.hotgrips.com/ (http://www.hotgrips.com/)) directly to the battery.
I would not risk overloading other wiring by splicing them in.
Post by: FJ1100mjk on September 16, 2014, 07:15:05 AM
I installed the same system on another non-FJ application.
You'll want a direct connection to the battery, to avoid parasitic voltage losses brought about by a different downstream splice.
If you go right to the battery's terminals, you may risk draining your battery, if you don't manually switch off the grips when you shut the engine off. Perhaps Oxford gets around this somehow. I don't recall. If not, you may want to install a relay triggered by a switched 12V source.
Marty
Post by: ribbert on September 16, 2014, 10:02:24 AM
Mine are straight to the battery and as I recall it is what the instructions tell you to do. I guess you could wire them through an appropriate relay.
I always forget mine over lunch and have left them on for an hour or more with no sluggishness from the starter. I have also run the battery flat twice. It becomes habit to turn them off after a while and if it's dark, you will see the lights on the controller.
I was going to install a light somewhere obvious as a reminder but I never got around to it and I haven't forgotten to turn them off for years anyway.
Mine would be about 6 years / 80,000 km's old and get a lot of use. You find yourself using them for comfort, not just to warding off cold after a while.
I have the Oxfords and would have originally been pleased if I got a couple of seasons out of them but they're still going strong.
I thought the RHS had died this year but it was just a wire I had dislodged.
You will enjoy them, they are a great investment.
Post by: movenon on September 16, 2014, 10:14:53 AM
I wired my heated grips through a relay controlled by the the ignition switch. Just in case I leave them on or someone turns them on accidentally while parked.
Post by: Derek Young on September 16, 2014, 11:04:41 AM
About 6 years ago I installed Oxford Heaters on my 86 wired to the battery with a relay so they turn on only when the key is on. When I got the 91, I switched them over. Now they are wired to an auxillary fuse panel on a switched circuit. It's a PC8 from Eastern Beaver(6 switched circuits, 2 unswitched). If you are going to add other electrical mods, a fuse panel is a good way to clean up your wiring. There are other brands available but here is a link to the one I used:  http://easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html (http://easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html)
Shortly after I met my wife (2010) I put a set of Oxfords on her Ninja 650R. She loves them also. Heated grips are a great way to extend the riding season in areas that get cold/wet. Add a heated jacket or vest and you can be relatively comfortable in some pretty cold conditions. I find the especially nice when going for evening rides where you leave in the nice warm sun and ride home in the cold and dark.
Derek
Post by: mz_rider on September 16, 2014, 12:39:59 PM
I've got a set of Honda heated grips on my bike. These are wired straight to the battery because they only operate if there is charging voltage (ie the engine is running). The "Heaterz" instructions say they should be wired to the battery rather than a switched live, so I assume they work that way as well.
Stuart
Post by: Bones on September 16, 2014, 04:09:25 PM
I've got oxfords and I have mine wired directly to the battery, because if they don't have full voltage the lights on the temperature controller will flash and they won't work. I think from memory they use about 30 watts each side so will need a relay if wired to a switched wire. Mine also came with a "brain box" so if you do forget to turn them off which I've done a couple times, they'll turn themselves off when the voltage gets to around 10 volts so it doesn't completely flatten the battery and a push start will get you going again.
Post by: Easterntide on September 17, 2014, 06:25:15 AM
Well suddenly i feel even happier about getting these. Wiring is straight forward and that may be my tonights project. They will be a surprise to her, and her hands get icy cold very quickly...so i may even get bonus points!
Thanks all.
Post by: magge52 on September 17, 2014, 08:50:32 PM
I'm installing a set of Oxfords too. Took some time to find a good place for them and the left handlebar turned out good. I'll use the bracket attached to the clutch m/c. Ran the wiring around the head stock. The tie wraps even had enough slack to run the wires thru. Only thing I need is the right sized star drive to take the bar ends off. Anyone know the size? Looking forward to toasty warm hands this fall.  :yahoo:
Post by: ribbert on September 17, 2014, 09:24:26 PM
Quote from: magge52 on September 17, 2014, 08:50:32 PM
For anyone else installing these, I have found this location to be good. The controller is stuck on with heavy duty velcro and the wire neatly fed through the top of the vent, no brackets or drilling (also, handle bars are a bit busy) In fact, all the accessories you see in the photo, other than the GPS, are stuck on with black heavy duty Velcro. Leaves you the option of moving things around as you add more stuff or change you mind. A secondary benefit is insulation from vibration.
(https://farm4.staticflickr.com/3906/15087008629_af1568a3f4_z.jpg)
Post by: Bones on September 17, 2014, 10:19:01 PM
The left side on the handlebars is a good spot, easy to reach and easy to see the lights when turning the temp up or down. I had to put a couple of small nuts under the bracket to pack it out so the bracket wouldn't bend when tightening the screws but otherwise fitting was straight forward.
(http://i1285.photobucket.com/albums/a586/the4ts/DSC_0349_zps265f4d96.jpg)
Post by: Easterntide on September 18, 2014, 06:14:30 AM
i tried a dry install last night and the throttle side went on nicely snug but the clutch side not so much. the end of my bar on that side is slightly burred so i'll file/sand that tonight but otherwise has anyone had issue? maybe i just need to convince it a bit more but there doesn't seem to be any flex to them.
Post by: magge52 on September 18, 2014, 07:56:24 AM
Quote from: Bones on September 17, 2014, 10:19:01 PM
That's where I'm going with mine also. I did mockups on the throttle side and on the plastic but I liked the way it will be easy to access with the non-throttle hand. Is that an oil temp gauge on the right?
Post by: Bones on September 18, 2014, 05:24:01 PM
Quote from: magge52 on September 18, 2014, 07:56:24 AM
Yes it is, I've seen a few bikes with the gauge mounted there so I followed suit, but in my case the panel around the gauge eventually cracked into pieces because I think I had the clamp too tight, and that doesn't go too well with old brittle plastic so a word of warning there. I put it back together with supaglue and it's been ok since, but if I can find a good replacement panel I might do a Skymasters or Movenon and make a dash up and mount it up near the ignition switch near the volt gauge.
Post by: ribbert on September 18, 2014, 05:34:14 PM
Just make sure your bracket is braced or pretty thick, those buttons require a very hard push with thick gloves on.
Post by: Easterntide on September 19, 2014, 06:10:36 AM
managed to get both bikes done last night and did the mountings on the bar, same as everyone seems to do. Of course thinking that starting at 100% makes the most sense i very quickly realized that 30% is the sweeter spot :-)
thanks for the help here everyone.
now i just need to find a way to keep the back of my hands warm!
Post by: FJ1100mjk on September 19, 2014, 06:25:14 AM
Quote from: Easterntide on September 19, 2014, 06:10:36 AM
These will keep both sides of your hands warm, plus your thumb.
http://www.warmnsafe.com/ultimate-sport-mens-heated-gloves/]  [url]http://www.warmnsafe.com/ultimate-sport-mens-heated-gloves/ (http://[url) [/url]
Having electric gear may have a some drawbacks, such as connecting and de-connecting, and purchasing a controller possibly. However, they are not dedicated to one bike, so can be switched between them if you suffer from MBS. After my aforementioned install of electric grips, that were sold witb the bike, a drawback to them in a way. I stuck with electric gloves and gear only. IMO, electric grips are okay for non-highway speeds, but their effectiveness suffers above that. As you mentioned, the back of your hands being cold. A numb and/or painful thumb is no picnic either, if you experience that. It's all subjective, of course.
Post by: ribbert on September 19, 2014, 09:50:27 AM
Quote from: FJ1100mjk on September 19, 2014, 06:25:14 AM
I've had heated grips for about 80,000km's.  They do not mean you can ride in light weight gloves in Winter.
Winter gloves distribute the heat much better but the back of your hands do still feel the cold.
Having said that, I didn't realise just how much they do keep all of your hands warm until I had a failure on one side recently. The back of that hand was suddenly waaaay colder than on the working side. While I believed the backs of my hands did not benefit from them, clearly they do, even if they feel cold relative to the front.
Heated gloves are no doubt better, but in my *climate, the grips do a magnificent job and allow me to ride all day in comfort in conditions that would otherwise see my hands freezing.
I also have a '93 which I think offers better hand protection.
A great investment in rider comfort.
* Most Winter rides start off in low single digit temps and drop to several below if headed for the hills.
Post by: FJ1100mjk on September 19, 2014, 11:41:45 AM
Winter gloves can help as you indicate, but dexterity is comprimised with them. Although I haven't tried all brands of winter gloves, so some are better than others for sure, they are for the most part bulky, which affects grasping the grips, and reaching for the controls.
Another benefit of say these gloves   [url]http://www.warmnsafe.com/ultimate-sport-mens-heated-gloves/]http://www.warmnsafe.com/ultimate-sport-mens-heated-gloves/]  [url]http://www.warmnsafe.com/ultimate-sport-mens-heated-gloves/ (http://www.warmnsafe.com/ultimate-sport-mens-heated-gloves/) is you can get around the bulkiness, and still have good dexterity too. Something to consider in regards to a panic situation, or working some twisties. The latter, not a factor, if droning down a highway. I guess.
Another benefit to consider when using electric gloves of this type, and regular non-heated grips, is keeping the diameter of the grip on the smaller side, easier to maintain a hold on them, than say the extra diameter of a heated grip, and the extra thickness that some non-heated winter gloves will add to the diameter that you're gripping. Something akin to using those foam grips, whose diameter is quite obvious, when you get off one so-equipped bike, and onto another that uses regular rubber grips.
As I mentioned in the earlier reply, it's all subjective of course.  :flag_of_truce:
Post by: Easterntide on September 19, 2014, 01:40:42 PM
We ride fatbikes (bicycles...w 5" wide tires) all winter long. anytime its in the - digits we just put on Pogies. Our physical effort + the shelter from the elements for our hands means that very very lightweight synthetic glove liners are comfortable down to -25c or so.
My partners hands get painful for her when they get cold. so if the grips don't do enough i may find a set of pogies that'll fit her CBR 125 as a backup option.
Post by: magge52 on September 19, 2014, 07:25:14 PM
I'll be the 1st to tell ya I'm not a mechanic but I've done routine maintenance stuff on my bikes, motorized and pedal, and cars over the years so I' know my way around a tool box pretty well and figured this install would be easy enough. I got the wiring routed with no trouble. Next was taking off the bar ends which were a bit of a stickler. They are torx ends so I pulled out my bits and found that 25s were too small and 27s too big. Okay prowled the web in search of 26s. Lots of kits with 25s & 27s but none with 26s. Getting desperate I tried my allen wrenches metric and sae still a no-go. So I thought maybe they will come off with a turn of a pair of channel locks. Sure enough wrapped a rag around them and one little twist and off they came. A few shots of WD40 under the grips with a little elbow grease and the grips are off. Okay now lets test fit the clutch side grip. Ha-that thing went on with a lot of elbow grease so much so I think I can skip the superglue. Only problem is there's about a 1/2" gap between the grip and the end of the bar...too short. Same with the throttle side. I bought the sport grips a while back planning to put them on the Duc but decided on the FJ instead. Looking at the instructions it looks like the adventure size will fit better. Is that what you guys have? I will stop here and get the adventures if that's the case and put these on the Duc as originally planned. At least I'll know the drill and get them on lickety split. Gotta get them on quick, we had the first frost last night.
Post by: Bones on September 20, 2014, 05:41:10 AM
Quote from: magge52 on September 19, 2014, 07:25:14 PM
I wasn't aware they came in different lengths, only different sizes to suit standard bars or the fatter cruiser bars. I've got the standard grips on mine which are 125mm long and with the bar ends fitted don't look out of place at all. If longer ones are available they might be better for you as they can be trimmed down a bit to fit if needed.
Post by: ribbert on September 20, 2014, 08:27:38 AM
Quote from: FJ1100mjk on September 19, 2014, 11:41:45 AM
Absolutely right, I hate thick gloves for just that reason. If riding in the cold I change gloves when I get to the twisties.
Heated grips, or at least the Oxfords, are not bulky. I have side by side bikes and I've never noticed any difference in feel. The fact they don't feel different would suggest they're not. I would not be surprised if they were standard diameter.
Post by: magge52 on September 22, 2014, 08:33:19 AM
Quote from: Bones on September 20, 2014, 05:41:10 AM
The latest version comes in three flavors, sport, touring and adventure with sport being the shortest at 4.48" (114mm), touring in the middle  4.72"" (120mm) and adventure the longest 5.19" (132mm). Each has their own grip pattern. It looks like the adventure is the best fit for the FJ for size and pattern. I did put the sports on my Duc and they fit well. The grip is slightly larger in diameter than the original grips but they have 17 years and 49k miles of life on them and the difference isn't enough to cause a problem for me. I'll be ordering the adventures for the FJ.
(http://[url=http://www.fjowners.com/index.php?action-gallery;sa=view;id=7775%5Dhttp://www.fjowners.com/index.php?action-gallery;sa=view;id=7775%5B/url%5D)
(http://[url=http://www.fjowners.com/index.php?action-gallery;sa=view;id=7776%5Dhttp://www.fjowners.com/index.php?action-gallery;sa=view;id=7776%5B/url%5D)
(http://[url=http://www.fjowners.com/index.php?action-gallery;sa=view;id=7777%5Dhttp://www.fjowners.com/index.php?action-gallery;sa=view;id=7777%5B/url%5D)
Post by: Easterntide on September 23, 2014, 06:19:14 AM
Without knowing any of this length issue i ordered the sport. fine on the clutch side but a tad short on the throttle. oh well. Our LBS only had cruiser so i did buy online. However they fit great (actually could trim a bit) on her cbr125 though...oddly enough its a sport bike :-)
